Results 1 to 10 of 10
    Europe
    Default trafic 2007 autoliv-608361500B passenger off
    i have a renault trafic airbag unit, i clear the file but i have passenger error. the problem is the passenger airbag is missing from factory. i remove the airbag cover and with resistor 2.2 ohmi in socket give "trigger lines configuration" error. i need a dump without passenger airbag ask.
    any help will welcome! thanks
    ovi_dk's Avatar
    On board
    Try this file and report
    B.R
    If u have the answer say Thank You!!
    Europe
    thank you ovi for your help. i test today and the error is still there. another idea?
    Europe
    i upload here diagnose result before remove the unit from car.
    original file is here, too
    morfej's Avatar
    Tested solution.
    br
    Europe
    thanks for your help morfej.
    i compare your file with my 608361500B 8200435346.rar file. the files are identical. not work with this dump. ask about passenger airbag, but this car not have airbag from factory. this is the problem. tomorrow i will try to set the active airbags with renault clip? what do u think about this? i have a chance?
    morfej's Avatar
    You have more change to be able to configure airbag with CLIP than with third party diagnostic, you are right.
    Is the car VIN really VF1JLBCB67Y217457 ?
    I guess the either configuration was not correct (or somebody play with it before you got the airbag) or it's not from that car in the first place.
    Clearing like 608361500B 8200435346.rar worked in couple of cases, so I don't believe it is wrong.
    br
    Europe
    i had same suspicions but the vin is correct and nobody play with the unit before me, because the lacquer from eeprom was untouched
    Europe
    solved. the delphi ds800 tester and renault clip give passenger error but i put a resistor 2.2 ohms on driver belt pretension and the error is gone...
    ovi_dk's Avatar
    On board
    Quote Originally Posted by auto_geo View Post
    Pls try to learn to say thanks to people who try to help you,Morfej give u a good file!
    Its not a hard job just press the thanks button if u want next time to have help!Here we pay with thank you! peresing the button!!
