Results 1 to 7 of 7
    Feb 2009
    Default bmw 318 1.9cc bms46 ecu how to read with galleto
    Hi guys!Has anybody tryied to read a bosch bms46 ecu with galleto1260 and succeeded?It's on a bmw 318 1.9 cc engine with ews 3.
    Netherlands
    no problem reading/writing with Galetto1250
    Feb 2009
    Quote Originally Posted by easytech View Post
    I 'm trying to read it on the bench but I can't.Does that kind of ecu has special pin connection?
    Netherlands
    K1 pin 5,6 GND
    K1 pin 1,2,7,8,9 +12v
    K1 Pin 3 K-Line
    Feb 2009
    I connected it that way,but it shows the following error message:errore invio INIT1:-5. It also opens a window inside saying:turn 10sec off and turn on the dashboard wait 10sec before continiue.Is there a possibility that I have to connect the ews3 as well,or read it with xprog?
    Netherlands
    Power supply at least 13v.
    I did a lot on the bench no problems but sometimes galetto give problems with some PC or laptop USB ports.
    Try another PC.
    Feb 2009
    Hi friend!I 've put 13,4volts, but nothing happened.It could be because my galletto is a clone,I don't know.Do you think I could read it with xprog,or INPA EDIABAS?I am thinking of something else too:is it possible that it wants the EWS3 connected, or a universal CAN immo emulator for opening the program?
