Results 1 to 10 of 10
    Oct 2011
    Default Updating my Channel List on Satellites - Help!
    Hi guys, i have a ET 9200 i am still a novice and trying so heard to learn everything so i don't have to annoy you all! I would really appreciate an easy list of instructions on how i can update my channels per satellite whether its one at a time or all at once doesnt bother me. whatever is easiest would be great. i would love to be able to receive new channels launched or moved transponder and also to get rid of the ones that have moved transponder or off air like dolltbuster etc...but i don't want to lose the way my channels are viewed on my receeiver like the different headings for each satellite 'movies' 'adult' 'sport' and generally how the satellite green button shows up the channels / services/new/package for each satellite. i dont know if they are updated automatically or whether i can do it easily...your help would be appreciated.
    Gods Country - Liverpool
    First off you need to download a program called DREAMBOX EDIT which is available on DK.
    You set it up on your PC, and make sure your settings are correct ie. username, IP Address and password. Also select E2 as the setting. You can then check the settings are correct.
    Once they are correct, you can download channels from your box. Once downloaded, you can ammend individual channels, change names, change boquet names. Once you are happy with your changes, you save, then send back to the receiver.
    Oct 2011
    is all that pretty easy to do? i'm really worried that i will end up deleting the channels i do have and end up with none!
    It is really easy to do. You download it from the STB, you can change it as much or as little as you want. Only then you save it, and if you happy, you can upload it back to the STB.
    You won't delete nothing.
    Mar 2009
    m8 the xtrend well the 9200 has a blind scan on it why not just scan the satellites you want and then you will have the updated list
    DK Veteran garry1312's Avatar
    Oct 2010
    Scotland/ Somerset
    Been speaking to Satlover for some time now. Although he has experience within sat he is new to the linux/ enigma receivers.
    I was wondering would the Catseye bouquets be best for him? I am fixed dish so there not bouquets that I have ever looked at so cant comment myself.
    I think if these are suitable for his setup then it would be ideal for him in the meantime then later on he can decide if he wants to create his own bouquets or continue to use Catseye bouquets.
    Rest In Peace Michael Mcharg, A true friend and although gone never forgotten. 11-10-08.
    Sep 2010
    catseye should be fine.
    Oct 2011
    thank you guys, now the hard part...actually updating the channel list when i've never done it before. will attempt it on saturday when i'm at home so i'll have the whole day to ask for help if i end up without any channels!
    Feb 2009
    Hi this looks like just what I wanted to know, but the problem for me network set up.
