Results 1 to 8 of 8
    Jan 2012
    Default mazda demio immo
    Need help with mazda demio 1999, immo box is dead.
    Searched all the forums, looks like no immo off for mazda with lucas immo box.
    Trayed to read mc68hc705b16 no success.
    ECU:B33L
    IMMO:LUCAS 28AS S/N6839020384
    When i get a used immo box how can i reprogram it to get it working? Need i get pin code from ECU or immo box?
    Dump from ecu 93c56 (16bit):
    00 00 00 5A 00 5A 00 5A 00 5A 00 00 00 00 00 00
    00 00 00 00 00 8C 00 82 00 42 00 72 00 56 00 0F
    00 00 00 01 00 97 00 B7 00 0F 00 00 00 01 00 94
    00 A9 00 0F 00 00 00 01 00 93 00 21 00 00 00 00
    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    Thanks for help
    koncimobil's Avatar
    Sep 2011
    soxxi
    post dump as bin/hex format.
    Jan 2012
    93c56 16bit
    Apr 2011
    ECU ready for coding.
    Repeat 5 times ignition on/off sequency, after this immo lamp stay lit and the ecu is in programming mode. ECU rewrites Immo eep contents and the key is programmed.
    Jan 2012
    Quote Originally Posted by mcgywer View Post
    When I get the immo box I let know if it works.
    Meat-Head's Avatar
    use the search botton - mmber darwins had a rice burner - the dump is on his thread, somebody mentioned the code
    Meat
    Jan 2012
    No success with another immo box,
    immo lamp blinks 3x
    Manual says: Fault 3, ID nummber is not input into immo unit after engine cranking
    Can not get into programming mode (MIL3 all time).
    I got the immo box with one key from same car, trayed with that key, MIL 3.
    Trayed to program the 93c56 with dump from mcgywer full with 00.. no success, engine not running with oem dump runs 5sec.
    The oem immo box was lucas 28as the box from junkyard lucas 19as, is that the problem?
    I searched 28as immo box did not found...
    use immo emulator for Mazda!
