Results 1 to 7 of 7
    Mosc
    Default VW Tuareg Position Sensor in Transfer Case
    Hello , I have problem with VW Touareg 2.5 tdi 4x4 , Do not turn on rear-wheel drive.
    I read two faults that do not cancel with the drive controller. :
    02039 - Position Sensor in Transfer Case (G398)
    009 - Open or Short to Ground
    02059 - Motor Temperature Sensor (G407)
    010 - Open or Short to Plus
    Please help, what might be causing these errors and where are these sensors located?
    vuno01's Avatar
    Europe
    the 02059 has nothing to do with it
    now the 02039 is the problem
    and i read somewhere that is
    a stepper motor in the centre diferencial
    that engages the low gear and regulates
    the 4wd operation that dies
    but just google it bro in some vw forums you
    can find that info even pdf about it
    you can also try in audi forums
    with the same problem in Quattro cars
    or Q7 or Q3 since thats all the same system.
    Mosc
    I nowhere can I find information about the fault , about sensor.
    Mosc
    Please tell me where is the G398, and whether it is a sensor or a potentiometer? I have the wiring diagram in the two languages, one shows the potwncjometr-G398 is a knob for switching (near the gear shift lever) in another schema potentiometer G398 is potensiometer as if the motor or the motor transfer case.
    is a potentiometer an is placed on gearbox.
    best regards
    Jan 2012
    I've checked the VW wiring diagrams it shows that both sensors (G398 and G407) as well as the control motor (V253) are in the transfer box. You can remove the motor and the sensor through the back of the transfer box. I think you must loose the drive shaft. if you want i'll send you some schematics.
    Best regards
    Junior Member vdubman1's Avatar
    OHIO USA
    hello there!! if you use vag com or vaspc what is the ecu part # and the software level please
    there is a flash if the level is not up to snuff
    that needs to be done and recheck
    note it still may need stepper motor on the transfer case !!
    let me know!!
