I have a DM 800 HD SE (Clone) installed with NewNigma & Transmission (Torrent Client). It has a internal 80gb HDD mounted.
When I activate my torrent client (Transmission), it works fine for several minutes (around under 10), then the picture and 800 HD SE permanently freeze, I can still hear audio, but I cant do anything with the box apart from turn it off and back on (from the switch behind the SE), remote control commands do not work, the torrent client `disconnects` (cannot administer it via web browser), also cannot Telnet to the box.
I tried limiting the slots & peers in `settings.json`, also limiting the download speed. But it still freezes. I also tried a bunch of different images (DreamOEM, Elite, Nemisis, and some others).. All were exactly the same problem.
Anyone using a clone DM 800 HD SE successfully with Transmission (or any other torrent client), with no problems?
Anyone kind enough to send me their working `settings.json`?
What else could be the problem?
I have attached the ipk of the version I am using, for you guys to tinker with if you havent before.
- Install `libevent_2.0.10-r0_mipsel.ipk`
- Then `enigma2-plugin-extensions-transmission_2.33-r0_mipsel.ipk`
- Start transmission, visit 192.168.x.x:9091
- Add torrents, and let it run.
