Results 1 to 14 of 14
    Nov 2010
    Default 2009 Nissan Altima- Mileage correction- Newbie help
    Hi guys. I have a Nissan Altima cluster on my desk. I want to change the mileage on it. I don't know the mileage on it now since I have no car to test with right now. It's more to learn with than anything else.
    Its a 2008 auto with push start.
    I'm trying to figure out if I can use a chip clip or do I solder points on it like some older ones. I can't seem to find any info for this cluster.
    Thanks for all the help.
    May 2011
    hi
    it has 2 eeproms of 93c66 and on the top eeprom is for km..
    nissan alog same
    thankx
    DK Veteran lashkar97's Avatar
    Jan 2012
    Indonesia
    u are open cluster its wrong .open BCM its behind the cluster its by Siemens vdo .open that and read data 9s12x . mileage value is inside BCM not in cluster . read that than change value and write back .and u r done
    May 2011
    hi
    no data is in dash ....
    93c66 inside the dash...
    thankx
    yes, digimile has right. The mileage in Altima 08 with smart key is stored in the cluster, eeprom 93c66 on top left side
    Dec 2010
    BCM? Oh my GOD.
    Jan 2012
    Indonesia
    may be i am worng but u can tri .because here all altima 2008 smart key start is data in side bcm .but i think digimile have more experince so u can check frist in side cluster .
    XmoDDeR's Avatar
    Mar 2011
    putting salt on leeches, one grain at a time!
    anybody have a power up for this vehicle 2009 nissan altima
    Reading is fundamental, asking is easy............................
    Dec 2010
    Altima usa 93c66 there is two eprom
    you have to choose one on the top
    XmoDDeR's Avatar
    Mar 2011
    No power up . Plug connections to test on bench
    Mar 2018
    Hi, I´m new in this area.. How can I do the calculation for this odometer?
  13. #13
    Jul 2016
    I have 07 altima. is it same chip?
  14. #14
    Dec 2010
    Bcm this is nice one))))
