Results 1 to 13 of 13
    Dec 2010
    Default opel corsa D waiting security time
    hi
    i need help, i try to programme a key for opel corsa D 2009.
    my probleme is the ecm not accept the originale pin code.
    in the parametre of immo the wait security time is enabled.
    i keep the car for 2 days with ignition on.
    security time still enable, how i can disable it.?????
    Have you changed any module ( Ecu, box-code, etc.) in the vehicle?
    Aug 2011
    uk
    Default corsa d
    are you using op com?
    Dec 2010
    i dont change any module
    i use opcom and orv commander but no way!!!!!!!!!!!!!
    Aug 2011
    uk
    Default re corsa d
    Why are you coding new key? Is it just because of lost key or spare? Only asking because if your trying to put the original key back into the car because of a non start situation it may be another fault i.e. bcm
    And youve put ecm!! are you trying to put keys into the ecm??
    PierreTheron's Avatar
    Centurion,South Africa
    Default Corsa waiting time
    You must wait for waiting time to pass with diagnostic tool connected all the time and then only code will be accepted..
    Good luck.
    Dec 2010
    in the parameters of ecm security time is 00.40.00
    i keep the car more than week with ignition on, but the probleme still exist.
    i think that the ecm must changed becouse the security time bloked. and no way to reset ecm.
    super jumbe's Avatar
    Livingstone
    I had similar problem once, I disconnected the battery for few minutes and then live the ignition on for 40 minutes mate, try you got nothing to lose.......
    Sep 2014
    hello friend how did u solve ur problem i have the same with vecta c
    reset ipc .sps bcm end programing new keys or old newer main .wen finis programing keys start engine end programing ipc 100% work. vin in all moduls identical? new models tid hawe comunication ?
    Sep 2014
    thanks for ur reply and how to reset all of them ?
    America
    Quote Originally Posted by kar407 View Post
    hi
    Hi. how you got the code you're using?. I ask it because some times the code that you get from informatic GM system is not the real code. Maybe you can wait the security delay time and after try to programm with the not correct code and the time will increase again. I think the best method is wait the security delay time , but you need be sure that you will use the correct pin. For it some times is better read it from some mudule.
    Regards.
  13. #13
    May 2017
    hi guys can anyone help me get security for opel corsa y17dt ecu please. vin no ADMXF80SE84484004. ECU IS IN SECURITY WAIT TIME, I CANNOT GET IT OUT OF IT. THANKS
