Results 1 to 15 of 20
    Feb 2012
    Default How to Burn,convert Lt3 iso to Lt2& play xgd3 games Offline,fixing unsupported discs
    [ame="http://www.youtube.com/watch?v=sb2nykp6Hgo"]Best solution to fix xbox 360 (Unsupported disc)..and playing any xgd3 game ever !! - YouTube[/ame]
    here the steps will help u and its clear enough !! CHEERS
    For people facing proplems with UNSUPPORTED DISC...
    1)xbox creator changing the lt with injecting and click ap2.5 patch
    3)going to the .dvD and open with notepad , and change the layerbreak to 1913760 instid of the 2133...
    4)img burn click CALCULATE OPTIMAL
    5)choose 4x as speed of burning
    6)choose over BURN METHOD just CLICK IT FOR GOD SAKE
    7)it will gives an error at 97 percent ITS K, move on and click cancel or watever
    8)it will give u another msg wether to close the track or watso ever JUST CLICK YESS
    and then this ****in lady will say OH NO, WELL **** HER TAKE THE CD AND IT WILL WORK
    Feb 2012
    Tested on dashboard 2.0.13599....Not sure about the newdashboards yet not tested ,,so its unsafe
    janobi's Avatar
    Mar 2008
    In a field.....
    So you post a tutorial for overburning of games when not using an ihas burner, and you think it will work for LT2.0 and unsupported disc error?
    Excuse me whilst I stop laughing!!
    fixing unsupported discs and playing any xgd3 game OFFLINE on ur LT2 xbox 360..
    Best solution to fix xbox 360 (Unsupported disc)..and...
    3)going to the .dvD and open with notepad , and change the layerbreak to 1913760 instid of the 2133...?? Why are you editing the layerbreak? Load .dvd file and layerbreak is set!
    5)choose 4x as speed of burning?? Only when using verbs mk003 unless you have hex edited to use other discs.
    6)choose over BURN METHOD just CLICK IT FOR GOD SAKE?? Why not just buy an ihas burner, and no need to over burn.
    7)it will gives an error at 97 percent ITS K, move on and click cancel or watever?? Its called truncated burns, this will not load forza 4!!
    8)it will give u another msg wether to close the track or watso ever JUST CLICK YESS?? Youre missing 3% of the game.
    If you want things to work, get an ihas flash it with max fw, update drive to LT3, and use mk003 verb discs. Thats the setup you want.
    I have burnt over 100 XGD3 games, and not one has failed, or had unrecognised disc.
    Feb 2012
    well guess what STOP LAUGHING !.. coz u dont have an idea that this method works with 100 xgd3 with me too and without getting any ihas WORKING WITH AN DRIVER so who is gonna laugh now , and for ur info truncate method is like over burning , but they got slight difference !! so iam posting that thread for people who dont got IHAS so they wont have to buy one to burn
    and ur steps IS ****ING OLD ..and i know and um working with this step u giving me btw ... this one for the people who got LT2 ..WITHOUT IHAS BURNER which i wont recommend them to get one , coz IT WORKS this method really works ...and tested
    Feb 2012
    forza 4 ? seriouslyy dude SYNDICATE , BINARY DOMAIN , METAL GEAR SOLID HD , GOW 3 ALL TESTED AND WORKS AND UR TELLING ME FORZA trueeeeeeeee.... and this 3% is NON IMPORTANT AND WONT EFFECT THE GAME , JUST A SECURITE ADDED TO XGD3 GAME for god sake...so not burning them isnt important anyway,, if ur OFFLINE
    DK Veteran martiboy's Avatar
    Nov 2008
    bonny scotland
    Quote Originally Posted by 7anafy View Post
    I don't see why anyone would go through this instead of just updating to LT3.0. It isint any good for
    Playing online which most people want. And as far as you telling people not to buy a ihas burner because the 3% that they can't burn isint needed is just stupid. All this is going to do is open more threads from noobs saying it won't work or it won't do this or that. Most people get the games for free so stop being a tight arse and spend a big ?15 on a new burner.
    Feb 2012
    Well i ALREADY GOT iHAS BURNER dude ....But there is alot who maybe cant afford it and wont afford ever year or to to update there LT, Maybe they dont want to take the risk to open thier xbox or something , and dude come on its a solution to play xgd3 game , why the hell are u mumbling about..and the TITLE IS PRETTY OBVIOUS OFFLINE GAMING NOT TESTED ONLINE...anyboady wants to play online just take his TIGHT ARSE from this thread and thank u ..and yeaa if this method works with all xgd3 and the burning ihas and updating too works with all xgd3 , who i would choose if i want to PLAY OFFLINE ? TO BUY OR NOT TO BUY !! man trust um not the stupid here
    janobi's Avatar
    Mar 2008
    In a field.....
    Ok my little friend. I CAN WRITE IN CAPITALS TOO!
    Let me educate you a little. Firstly, there is no such thing as offline play!! Your nand stores all the info, and will upload it to live once you connect. So your method is already debunked.
    MS are fully aware of truncated burns, and CIV checks are being implemented to stop these working. Hence needing the last 3% of the disc.
    If people are silly enough to follow your instructions, rather than spending the ?12 on an ihas, then thats upto them. However, your tutorial, is likely to get people banned/flagged.
    C4 has said that truncated burns are not advised, and people should update, and get an ihas. Im going to go with what he says, rather than some kid who knows sweet FA.
    All the games you listed, none had the CIV checks. The last 3% of the game is important, otherwise wtf is it doing there? Also refer to point 1.
    To any member that cannot update their drive themselves, I will happily update your drive for free. You just cover the postage, that way you are safer!
    Final point, I would check this out, as your comprehension of the English Language, and sentences is horrid.
    http://www.eslbee.com/sentences.htm
    Feb 2012
    Thanks For the English Lesson Teacher CHANOPI or is janopi ooh sorry , and thanks for the lesson u gave me anyway about the update , well why i would connect online anyway mmm ? if um planning already to play always offline why i would come one day and play online...and wow i never knew there no such thing as playing offline REALLY DUDE well thats new .. k this is not my method i posted , but works and never got banned for a year now so mm thanks for the incredible informations dude and the game i listed not only them i burned actually others WHO I AM SURE GOT the CIV ..
    and me writing in capital ...The problem is the truncate method never worked with me , only the overburn , maybe they are the same , but truncate never worked always gave me errors !..so to me and my own dashboard they arent the same .. and Dude for god sake tis thread is for the people who want to afford and dont want buy ihas and will play all thier life offline and never connect so what r u mumbling about anyway !
    janobi's Avatar
    Mar 2008
    In a field.....
    Thanks For the English Lesson Teacher CHANOPI or is janopi ooh sorry , and thanks for the lesson u gave me anyway about the update , well why i would connect online anyway mmm?
    There you go, I can actually read what you wrote now, although it still doesn't make any sense.
    If you only play offline, then you have technically banned yourself. Although CIV checks are present offline too, as they are built into the dash and disc.
    From what I can see, I haven't mumbled once. You said in your first post, that this is the method, and works for you. Then a few posts later you state that you have an ihas burner. So how are you truncating discs or even overburning them? Surely you have flashed your ihas? Otherwise, why get one?
    You would need to connect to live to take updates. You can of course install them via USB. However, those checks are still present within the dash updates, so your point is mute.
    Never being banned for a year eh? Funny that, as XGD3 only came out a few months ago. So before that you would of been fitting all the data on the disc. Or are you saying you had XGD3 games before anyone else? lmfao. And for you info, there have been no console bans since 09. When over 1 million people were banned.
    Clearly you didn't know about CIV checks, yet now you're claiming to have burnt them and played without errors. How I 'd to myself. I'm 99% sure that the imax guide states that truncated/overburned methods are not advised. This comes from C4 (The guy who's FW allows you to play backups), yet you know better? PMSL!!
    Final point
    http://www.copyblogger.com/how-to-read/
    Its Janobi The one and only!
    Feb 2012
    looool this conversation becomes really exciting !! Bad ass English teacher i have an ihasburner and i tried and i also got ANOTHER LAPTOP WITH A RANDOM DRIVER omg how would that happen and i tried different methods , shit that is soo hard right ? haha ... and when i said about the year , well come on man dont be soo harsh okay dude i didnt get banned from 6 months is it okay with u ? Driver san francisco first xgd3 released from like 6 months or something so umm whatever...anyway u got the point dude i surrender so SHUT UP ..guys its unsafe method ..haha
    AND DUDE I SWEAR TO GOD IAM NOT CLAIMING THAT I TESTED THE GAMES IWTH IT , well it really works and i finished plenty games with it ..actually thats the thing which still makes me stubborn until now
    janobi's Avatar
    Mar 2008
    In a field.....
    I dont get the random drive part? Sorry!
    DSF was released Australia on September 1, 2011, Europe on September 2, 2011 and North America on September 6, 201. So even with poor maths, thats 5 months max!
    Imax came out at the end of september I believe. So thats 4 months ago, so again your maths is poor!
    As I stated earlier, been no bans since 09. So wtf are you on about?
    http://en.wikipedia.org/wiki/Contradiction
    Just read the above, and know that you have been owned.
    I dont really have an issue with you or your methods, however your advice is poor, unclear, and random at best.
  13. #13
    Feb 2012
    why u dont get the DRIVE PART ... u didnt get anything anyway its not wierd
    6month or 5 month , well not being banned for 5 month playing this game everyday! when oneday um banned i will come and gave u a THANKS .. so dont wait for it ever hahah
    and yeaa ITS NOT MY METHOD DUDE GET OVER UR SELF ,And ofcourse u dont have a problem with me dude its for ur best anyway,um here one of the people who dont care if the get banned,but still rudness aint my style soo..
    and now ur the bad ass MATH TEACHER DAMNNN CHANOPI THE ONE AND ONLY LOOOOOOOOOOOOOL...i love u dude ur hilarious
  14. #14
    janobi's Avatar
    Mar 2008
    In a field.....
    Membership to my fan club can be arranged for a large donation to this site.
    You could play DSF for the next 6 months everyday and not get banned. There has been no bans since 09. Or do you need me to write it in capitals for you to understand? lmao.
  15. #15
    just keeps saying AP25 cannot locate dae.bin file
