Results 1 to 13 of 13
    Jun 2011
    Default how to get security code to reset opel astra ecu 1999 model
    hello friends i need to change ecu for one opel astra 1999 model i have to reset it i baught one from a scrap yard but i didnt get the security code so anybody can help me to get it ? the vin readed from the new ecu is WOLOTGF08W5267694
    thanks in advance
    DK Veteran m3m5's Avatar
    mate you need post dump or ask to dealer, dealer i think is 18 euro
    Excuse my english, it's poor
    Jun 2011
    hello friend thank u for ur answer but i am asking for the security code to can reset the ecu with my op-com and not the pin code to program the keys
    Birmingham UK
    Quote Originally Posted by elmaalouf View Post
    Security code to reset ecu is same as pin number to program keys so m3m5 is right. You will have to go to dealers with new ecu chassis number and car registration number to get pin code for new ecu:: On some astras I think it's 1.6l you can get a pin code with opcom. Do a search on it it's in garage section. Other than that you will need a dump from immo ring/antenna around ignition switch to get the code. Immo ring has to be from same car new ecu came from.
    Last edited by gregk; 28th February, 2012 at 10:27 PM. Reason: just added couple of things
    Jun 2011
    I got the pin code from the immo dump and try it not the same and its lohic cuz the ecu is from another car so i dont know what can i do to reset the ecu any help pls?
    west mids, uk
    gregk is correct, go back to scrap yard and get ring from aroun ign lock, read tms and post dump, you will get your code, or....
    if its a 1.6cc petrol, you can read pin code from ecu with op com, check for details on lupu sandu's posts.
    ninja
    DK- The Bogs Dollocks!!!
    NEVER SAY IT CANT BE DONE!!
    The thanks button works wonders!!
    DONT SEND ME PM'S ASKING FOR OTHER MEMBERS WORK OR PASSWORDS
    Birmingham UK
    have a read thru this post it's for Y17DT ECU
    http://www.digital-kaos.co.uk/forums...l-immo-195124/
    And if engine is Z16SE
    Quote Originally Posted by schumy1502 View Post
    on the Z16SE the pin code can be extracted with opcom 090420 and then can be reset
    Birmingham UK
    Also if ecu locked you out you'll need to leave ignition ON any thing from 15min to 24hr for ecu to allow you to put code in again.
    Have you got pin code from your original car as well???
    If yes you can re-set new ECU providing you have a good pin code for original ecu and new ecu.
    I remember having problem reseting my ecu in my astra I had both codes for my car and new ecu but none worked. What I had to do is Virginise my immo ring first , then I had to code immo ring with new ecu's pin only then I could virginise ECU and immo ring. After that I wrote original pin to ECU and immo ring so that I could use my original keys and immo chip. Hope you get what I'm trying to say.
    Jun 2011
    I have tje pin code from the original ecu but dont have it from the new one so what can i do?
    Birmingham UK
    You have been told what to do in above posts by me and other posters. Thats all I can help you with sorry.
    Jun 2011
    How did u setteld ue problem?
    Birmingham UK
    I did have an immo ring with my new ecu so read dump from Tmc chip and got the code. Then programed as above.
  13. #13
    Busswil Switzerland
    solution is put new ecu read win # go to opel diler and take pin code other solution is avdi with opel pin code option 1200e or codecard.lt
