Results 1 to 13 of 13
    Feb 2012
    Default Neither a "services" nor a "lamedb" file was found in directory on the Dreambox.
    Neither a "services" nor a "lamedb" file was found in directory "%" on the Dreambox. /var/tuxbox/config/
    I'm trying to setup DreamboxEdit and when I select the option to "Recive Files from the Dreambox-I get the above message, can someone help me with this, I've been trying to setup my DM500S box, I installed the Neutrino 14.4 Image, The image is great but there are a large number of channels that do not work, just display a blank screen, I greatly appreciate your help, I'm loosing the will to carry on with setting this up.
    Last edited by khalsa techi; 4th March, 2012 at 01:55 PM. Reason: Did not finish my question
    DK Veteran Rodbouy's Avatar
    Wrong section mate and goto dreambox edit options and change path from enigma2 to satellite then save
    Feb 2012
    The DreamboxEdit Option screen shows the following:
    File paths on the Dreambox: (this is the current settings)
    Services & Bouquets files> /etc/enigma2/
    User bouquet files> /etc/enigma2/
    Satellite.xml file> /etc/tuxbox/
    Path for Picons on dreambox> /media/usb/picons
    Where am I going wrong, which path should I change, sorry for being in the wrong section, but thanks a million for your help.
    Feb 2012
    I changed the first 2 paths from /etc/enigma2 to /etc/satellite and then saved it, but then got the same error.
    what bouquet list you adding?
    Feb 2012
    Where do I find the bouquet and how do I add this, I'm sorry but this is all new to me.
    Feb 2012
    Default DreamboxEdit
    I'v removed DreamboxEdit v5 and have reinstalled this with version 3 - but still get the same error, see below.
    Connecting to 192.168.1.6.
    Connected.
    Dreambox response: Login successful.
    ** Retrieving file list of "/var/tuxbox/config/enigma/" **
    Starting FTP transfer
    Transfer complete
    Transfer complete
    Neither a "services" nor a "lamedb" file was found in directory "%" on the Dreambox. /var/tuxbox/config/enigma/
    Check the dream path settings on the option panel to point to the correct Dreambox directories and try again.
    Disconnecting.
    Disconnected.
    I Have a D500S box with Nuetrino v14.4 image installed, with DreamboxEdit Version 3.0 on my PC. PLEASE HELP !
    what bouquet list have you loaded in to dreambox edit for your box?
    go get sgt flipflp enigma 1 bouqet
    then extract the folder, load in to dbedit then ftp them to box
    Feb 2012
    Hi thank for the reply, really apprciate it. I have extracted then files, opened the DreamboxEdit, clicked on Open and it placed a number of channels on the left pane when I selected the first option which was "bouquets". I selected the FTP icon-"Send files to Dreambox" but got the following message.
    Connected.
    ** Getting directory list /var/tuxbox/config/enigma/* **
    Transfer complete
    ** Sending file "/var/tuxbox/config/enigma/services" **
    Transfer aborted
    Error sending file "services" to the Dreambox.
    Disconnecting.
    Disconnected.
    Feb 2012
    Hi there,
    I've managed to FTP to the box, which then required a reboot.
    I was then able to Recieve files from the Dreambox.
    I had to change the path in DreamboxEdit to get this working:
    It was set to /var/tuxbox/config/enigma/ and is now /var/tuxbox/config/zapit/
    there was no path that had enigma when I checked using DCC.
    What do I do from hear to get all channels working, as there are a lof of them just showing a blank screen.
    merseyside
    There is a guide in sgtflipflops settings link above
    Aug 2012
    i have this problem.
    Connected.
    Transfer complete
    Transfer aborted
    Disconnecting.
    Disconnected.
  13. #13
    Jun 2009
    i have the same problem this is what i get Neither a "services" nor a "lamedb" file was found in directory "%" on the Dreambox
    what does it mean help please
