Results 1 to 7 of 7
    Feb 2010
    ...where was Columbus
    Default 2008 Chevy Malibu
    Can some body advice me where is mileage located in this 2008 Chevy Malibu cluster's dump?
    EEPROM 93LC66
    Jan 2010
    USA
    2004 and up Malibu mileage is in the BCM.
    Feb 2010
    Quote Originally Posted by andydz106 View Post
    Not BCM only. I changed the cluster with different value on it that I see now. I change the mileage with my proved tool that I use all the time with this kind of car with no problem and I see new changed value in BCM but not on cluster. That's the promlem.
    I need some advise where is the mileage in the cluster dump I left it here.
    smokey08's Avatar
    Mar 2010
    Essex, UK
    How many km does it have in it?
    Feb 2010
    Quote Originally Posted by smokey08 View Post
    32360 miles on this cluster but in BCM is 49100 mi
    Feb 2010
    nobody knows????
    I have still problem with my car
    Jan 2010
    canada
    the design is when the value inside the bcm is higher the cluster will update to the bcm value
    if the bcm value is lower then the cluster will not update until the bcm reach the cluster value
    did dozen of those malibu , bcm only all the time
    Paul
