Results 1 to 13 of 13
    obdmaster's Avatar
    Never never land
    Question SAGEM S300 ecu, no 95160???
    I have this sagem ecu 8200298457 , s3000 to code swap unfortunately there is no 95160, just L9615D which is a can bus transiever.
    Is it impossible job??
    What do i swap???
    Many thanks
    Obd
    You need every tool in the book, to do this auto locksmith job.
    DK Veteran itrade's Avatar
    there is somewhere 95160
    must have the flash too
    "Your life burns faster. Obey your master."
    IMMO ..... SEEK AND DISTROY
    Do not ask me old passwords for RAR archives! do not remember!
    Do not ask me for passwords archives of other people!
    obdmaster's Avatar
    Never never land
    Question pic of pcb
    Attached is pic of pcb there is no 95160.
    If there is please could you mark where it is??
    Two years ago I repaired this ECU but I do not remember where it found the eprom ... but certainly I know it's there.
    What is the other side of the board?
    obdmaster's Avatar
    Never never land
    Unhappy
    Quote Originally Posted by itrade View Post
    other side of board is stuck to the aluminium cover m8
    there must be something my friend
    God loves the brave
    Heat the aluminum cover and carefully peeled off
    Jun 2009
    in other side is the memory
    obdmaster's Avatar
    Never never land
    Thanks to all replies found it.
    Many thanks
    Obd
    obdmaster's Avatar
    Never never land
    Question
    ok i removed both 95160 and read them dump attached.
    The original ecu was burnt and the data looks bad to me, so i used dump from replacement unit and put threw scp to make ecu autocoding supposedely. As anyone tried this as car is at other end of country!!!!!
    As anyone got good immo off or autocoding for sagem s3000 or is scp autocoding dump good??????
    Many thanks
    Obd
    Junior Member panos2's Avatar
    Mar 2012
    Hellas // korinthos
    hi to all
    Jun 2009
    i hAVE tried this ecu before 2 months in a renault laguna .
    my job was to make ecu virgin or immo off.
    the programing will be done from the renault dealer
    i have tried a lot of virgin files but nothing
    emulator does nor exist as far as i know.
    the memory is locked after adress 600.
    i colleges told to me that the virgins ecu comes with vin to reprogram by clip.
    i would be glad to send you my 2 months project.
    send me email
  13. #13
    PierreTheron's Avatar
    Centurion,South Africa
    Quote Originally Posted by gadroulll View Post
    send me email
    Same story here .
    Seems new ecu from renault gets coded online to match to the vehicle specific configuration off sensors and engine..
    So best way is to move 95160 to other known ecu that came from exact same car configuration . Then hope for the best..
