dreamboxedit is software for editing and sending new bouquets/channels to your box. you can download it on this site, then configure it to be able to connect to your box.
you then get a list of those channels from somewhere like sgtflipflop or vhannibal etc related to what you want to see (which sats you can see).
you load these into dreamboxedit, then use dbedit to send these (collectively known as settings) to your dreambox.
after an update the new channels appear.
btw, have you checked that your tuner config is still ok. not been changed to disecq switch or positioner set wrong...
menu>setup>sat searching...
finally, if you are spending ages on this, a relatively quick fix is to reflash your box - you do have a backup dont you
