Results 1 to 15 of 15
    Top Poster GSI2's Avatar
    Feb 2009
    moon
    Default BOSCH ESI[tronic] 2012 online UPDATES
    Want to share something that I found regarding the online updates of 2012 cause I saw users sharing the updates in another forum, but they wore hosted in rapidshare... and if you don't have rapidshare account it takes a few hours to days do download.
    If you use download manager it will check your ESI[tronic] ID send it to there servers and only then you have access to download the updates, it means even if you have a legal ESI[tronic] contract you will only get the updates if you are using the ESI[tronic] that is registered with them, well this is a nice piece of security this way you cant give your userid and pass to some friend so that he can update his ESI[tronic].
    [sarcasm] Bosch security keeps getting better!!! they are getting smarter!!! implementing updates secured by the download manager where you need to type your userid and password provided by them...[/sarcasm]
    I have a legit account but the Fuc%$*** manager kept saying wrong userid or pass so I started to look around all the manager crap, and I found out the links to download directly from there servers no questions or passwords asked
    and the fun part is the updates don't check your ID so you can install the updates even if you are using kegened ID
    EDIT: Links for 2012-2 also attached.
    links attached.
    Cheers
    link fails.
    Feb 2009
    moon
    Quote Originally Posted by aatakan View Post
    link fails.
    In what part of the globe are you m8?
    drakov's Avatar
    Aug 2008
    links work fine.... nice find
    Check out The Number 1 Resource for all Automotive Software with a lot of patience you like me will find what you need...
    Liteace's Avatar
    Mar 2009
    On a rock
    Links work fine for me, downloading now.
    hi! need help, can't locate DDC on my ESI tronic 2012. i've search it on my control panel after installation. i'm running Win7 ultimate OS. someone help pls. thanks
    peko's Avatar
    ok, but after installing update and reboot
    tool ask activation ?
    program can't detect the KTS 570.. on other computer i used to install it using the DDC but now i can't find where it is.. i don't know why it hasn't appeared after installation, is there any other way the program can detect the KTS 570 ?
    and oh.. ESI 2012 has been activated
    Feb 2009
    moon
    Quote Originally Posted by bcsc31 View Post
    Open any 1? ESI[tronic] DVD & install DDC from
    %YOUR DVD%:\Esi32\Kts500\BAS_Setups\DDCSetup.exe
    Thats the only way you cant setup your KTS easy, run setup follow program instructions.
    Liteace's Avatar
    Mar 2009
    On a rock
    Sorry for being a Div again but what do I do with this, Ive downloaded it and when I click on one of the downloads I get error message saying:
    SD-setuo could not be successfully completed as the necessary software has not been installed or is................................................ ........................
    blar blar
    Feb 2009
    moon
    Quote Originally Posted by Liteace View Post
    blar blar
    You need to have ESI[tronic] installed to use them.
    Liteace's Avatar
    Mar 2009
    On a rock
    Quote Originally Posted by GSI2 View Post
    I have got it installed ?
  13. #13
    Feb 2009
    moon
    What version do you have?
    This updates are only for 2012 version.
  14. #14
    Feb 2009
    moon
    Links for 2012-2 also attached in first post.
  15. #15
    bobolin4o's Avatar
    Bulgaria, V. Tarnovo
    And for 2012.3...
