Hi, anyone knows the procedure to flash the ecu m3.8.3 of a3 without desoldering flash eprom? I read on the web interface can be done with mpps, spi or revo3, but I know the procedure or connections. -
Thanks in advance
Thanks in advance
here is the schematic
BusCan (19th September, 2020), Col19 (13th October, 2020), mexanico1971 (11th January, 2018), sato-bmw (15th February, 2015), Yhoni (14th June, 2022)
Thank you very much friend, this is helpful, you know if it works mpps clone?
You can only write files with mpps, it wont read the file, so you will need to find your original file or remove the 29f200xx flash and use programmer to read
Kess v2 FW 5.017 full unlimited token - Ktag 7.020 full unlimited token
ALL EDC17/MED17 EEPROM CHECKSUM + VAG IMMO OFF BY EEPROM - NO SAFE
EDC16/17 POPCORN - ME7/7.5 ANTI LAG - LAUNCH ALS/NLS
DPF EGR DTC SCR, Custom Tuning, Damos Translation, FRF / SGO Files
Professional Engine Software Development
If ok, the idea is to read the file orig, and programming via flash are experimenting with different chips tuning
sorry for my English
MPPS shows software number .. post it and i'll give you your original file
I have not yet mpps, I want to buy mpps v5.
Do not know what works best
Buy SMPS MPPS V5.0 Tuning Remap Chiptuning CAN Flasher
or
SMPS MPPS V5 Tuning Remap Chiptuning K+CAN Flasher Cable
Friends, what version of mpps need for this?, China v12 clone works ok?
Thank you again
all versions work ... just interface needs to be good
Thanks for your reply, I had my doubts as M3.8.3 not appear in any version of interface
it appears as 5.92![]()
Col19 (13th October, 2020), pawelelectro (20th March, 2021), sato-bmw (15th February, 2015)
Very good friend, I was clear, thanks for your help again
Hello again friends, I came mpps programmer, this is data that gives the programmer without removing the ECU of the vehicle.
Anyone have the original file of this ecu? I want to avoid removing the EPROM from the original plate
Bosch Software Number:
Bosch Hardware Number:
Vw Software Number: 06A906018CJ
System Type Number: 1.8L R4/5V
Thanks to all
you have to give pin 43 (shows on mpps window check if is correct pin) on ecu 12v power for mpps to show soft version or write a file ... this way you tried wont work
(\__/)
(='.'=) This is Bunny. Copy and paste bunny into your
(")_(") signature to help him gain world domination.
I was very anxious and removed the eprom, these data don ...
Bosch
0261206516
1037350781
I'm trying to make a good chip tunning. now the turbo pressure varies between 1bar and 1.4bar
