Results 1 to 4 of 4
    DK Veteran DNG2010's Avatar
    Mar 2010
    Heaven
    Default 2008 Ford Econoline E250 4.6 Super Duty - Dash Change
    Hello Guys,
    Need help please... customer brought me a Ford E250 mfg date: 09-2007 ...
    the dash is faulty and customer purchased a new dash but after i tried installing the new dashboard, the car wont start. I tested by putting the old dash and it starts again.. So I'm guessing there is IMMO or something else like VIN check...
    Anyone have any ideas?
    DNG
    DNG
    Due to a severe downturn in the economy the light at the end of the tunnel has been switched off until further notice.
    Jul 2010
    U.S.A
    copy-paste eeprom area from old one to the new one...9s12 inside ?...or use diagnostic tool for adaptation
  3. The Following User Says Thank You to maumaumau For This Useful Post:
    SASSPEEDO (11th November, 2016)
    Mar 2010
    Heaven
    Quote Originally Posted by maumaumau View Post
    do you know which diagnostic tool for adaptation?
    DNG
    afitijuana's Avatar
    May 2010
    YOU DON'T REALLY NEED A DASH ADAPTION YOU CAN PROGRAM A KEY WITH PATS, AND YOU PROBLEM WILL GO AWAY.
    ANOTHER OPTION IS :
    YOU CAN REPLACE THE INFORMATION ON THE NEWONE WITH THE ONE ON THE OLD ONE.
    IF SOME DAY YOU NEED A ADAPTATION OR MODULE CODING YOU HAVE 2 OPTION.
    1.-fORD ROTUNDA OEM FORD TOOL
    2.-MONGOUSE INTERFACE
    BOTH WILL NEED A SUSCRIPTION FORM MOTORCRAFT WEB SITE.
