Results 1 to 11 of 11
    pepi's Avatar
    Default Berlingo 2001 dash problem
    Hi ,I need good dumps from dash and BSI
    Citroen Berlingo 2001 HDI
    I got the car with this problem ,dashboard is allmost dead
    (check the photo) nothinks working at all , km 000000 ,needles not moving.... just like when you connect it on the bench without BSI. The car is starting ,I opened BSI and I see someone was working on it before.
    celje, slovenia
    you have soldering issues in bsi try to resolder all resistors vhere you solder those 8 vires and all pins vich go from resistors and those pins vich have to be lifted. 100% the problem is in bsi and bad solders
    wiseman's Avatar
    would agree BSI problem, had same issue with same model of bsi, had been plugged back into the car with the battery still attached i think caused the problem. read Nec if possible and flash into another Bsi.
    pepi's Avatar
    Today I have tryed another BSI from junkyard without succes
    Quote Originally Posted by pepi View Post
    First of all I think you must use Lexia to check for problems ...
    maybe BSI is wrong programmed , maybe cluster is defective or maybe is a problem on VAN network ..
    pepi's Avatar
    I try to connect with the diagnose ,but there is no power at DLC connector, I have checked all fuses but they are all ok.
    I suppose there must be power +12v at pin 16
    Sep 2012
    Have u sorted the problem out if not check the bus wires (red) n (white) behind the radio they are wound together if an aftermarket radio was installed the bus wires can get the chop by accident and the bsi n cluster canot talk.
    Jun 2011
    hello friend i have the same problem i know ur post is old but how did u settle ?
    thanks in advance
    pepi's Avatar
    This is long time ago , but I remember the problem was at wires not on dashboard or BSI.
  10. The Following User Says Thank You to pepi For This Useful Post:
    elmaalouf (25th January, 2014)
  11. #10
    Jun 2011
    Thanks friend
  12. #11
    Feb 2014
    portugal
    hi,guys
    hi have a problem like this with one 2001 berlingo.
    and it was a broken wire from the conector to the relay behind the battery.
    after that, the dash lights turn on without the key on the ignition .it was the relay behind battery.i replace it and everything is good now.
    regards
