Results 1 to 10 of 10
    Post Nissan almera pin code not accept
    Hi,members l have nissan almera petrol model 2003 it have problem on nats system it not accept pin code immo .l change 5 immo all it show pin code invalid and car not start if l test same immo and pin code on other car it accept and car started .please any one have idea of this ?.thanks members
    keysph's Avatar
    Feb 2011
    1. On petrol Nissan vehicles, if a problem exists within the Engine Management system, then key programming will be blocked.
    2. If the immobiliser has been locked (incorrect PIN entry), disconnect battery and re-connect, then turn ignition on/off three times.
    3. On later systems there is also an input from the Audio system, which if disconnected inhibits the starting of the vehicle.
    Do you have any errors read?
    Hi, try again l follow your instruction still same problem .any idea thanks
    keygargoil's Avatar
    is it the blavk box under the drivers side you have changed or an aerial
    l change on ignition side key reader.or the other box l must replace?.thanks
    keygargoil's Avatar
    the immo for nats 2 is a small siemans box and ecu the aerial isnt coded for nats 2
    this car it nats 5 .l try to change immo box and ecu it show same problem in valid pin code .please anyone have wiring diagram of nissan almera nats 5 system?. thanks on advance.
    fixanycar's Avatar
    here
    Question 2006 Nissan Xterra PIN Problem too
    I'm experiencing the same. 2006 Nissan Xterra PIN is not VALID message. I think i need another Calculator.
    Nats 5
    CalsonicKansei
    Visteon
    284B1 ZP01C
    5X28
    65033
    9460 from c66 DUMP. Maybe ECU problem.... A lot of Diff Faults in ECU for CAN Communicationbut I can read to any module. TCM was replaced
    Hi.members l have got almera ecu+key+immo and test to other car it start fine one car nisan almera it refuse to start . l check injector power on it give 12v but if l cranks no injector pulse it less than 7v .l check relay ,scanner no foult .please member any idea of this ?.thanks on advance
    fixanycar's Avatar
    here
    Thumbs up
    Quote Originally Posted by abuuauto View Post
    Check Grounds, battery grounds are horrible on Nissans, check Injector resistance. Engine Wiring Harness could be at fault.
    P.S. My problem with no start was due to bad PCM. Comm was OK but it had CAN problem and that is why I was not able to programm keys. Very frustrating but enlightening
