Results 1 to 15 of 22
    Default touran edc16U1 not contactable
    i have a problem on a touran 1,9 pdi 2005.
    sometimes car does't start also engine ecu control lamp is not lighting.
    when this failure is i also can't make diagnostic with vcds.
    when i switch ignition off and on about 10 times, sometimes car starts, and i can drive without any problems till i stop it.
    the engine control light glows with ignition and car starts, also i can make diagnostics.
    someone knows this problem?
    ecutuners's Avatar
    Apr 2011
    United Kingdom
    Check if ecu has been opened, if it has reopen it, clean pcb with isopropyl alcohol, and re-seal it properly.
    Kess v2 FW 5.017 full unlimited token - Ktag 7.020 full unlimited token
    ALL EDC17/MED17 EEPROM CHECKSUM + VAG IMMO OFF BY EEPROM - NO SAFE
    EDC16/17 POPCORN - ME7/7.5 ANTI LAG - LAUNCH ALS/NLS
    DPF EGR DTC SCR, Custom Tuning, Damos Translation, FRF / SGO Files
    Professional Engine Software Development
    thank you will check tomorrow, found on a german site that this problem is a known issue. P01314
    VOLKSWAGEN-VW 038906016 Bosch 0281010734 - VW (Volkswagen) - Motorsteuerger?t - Bosch EDC16U1
    do you use a special glue or silicone to seal the ecus?
    micromax's Avatar
    South Poland
    use hot air.
    i use grey glue from Berner without vinegar. lead not like vinegar.
    spawns3's Avatar
    Portugal
    Have similar things happened to me, but only one time was the ecu. other was contacts from "cannon" key.
    what i forget to say when i switch the ignition on the radiator van is starting...
    sorry what do you mean with "cannon" key?
  7. The Following User Says Thank You to chriskross For This Useful Post:
    JFR-Tuning (19th July, 2014)
    spawns3's Avatar
    Portugal
    Quote Originally Posted by chriskross View Post
    The ignition lock contacts, if the fun work , the car as in emergency mode !
    Portugal
    The problem is bad contacts in MPC. To solve this problem reballing them os re-heat carefully MPC.
  10. #9
    is it possible that there is a problem is flash.
    maybe there is a bug in the checksum, i read with bdm please can someone take a look on it.
  11. #10
    you could have the hot start problem or i thing it s relay 19...it s one of the relay 206...or 19
  12. #11
    Top Poster georgegt's Avatar
    Romania
    Change ECU Relay
    If is not cupled the ECU dont boot and no comunication
  13. #12
    t77's Avatar
    Poland Lodz
    Hello Chrisskros .I had same problem like you in Seat Altea EDC16U1 ,I was buyed used EDC16 and replace EEPROM and FLASH (from orginal EDC )and nothing the same problem ,but I back to flash from used EDC and all ok .In 100% you have damage Flash.Regards
  14. The Following User Says Thank You to t77 For This Useful Post:
    Griunvaldas (27th August, 2013)
  15. #13
    i already checked ecu power connection i got 12V on pin 3,5,6, 18.
    do you mean the relais in the fusebox engine bay, i already changed them.
    t77 you had the same problem was your ecu also
    03G906016 DK 6247
    is this possbile can flash damaged by itself?
    can someone help me with a good flashfile please.
  16. #14
    t77's Avatar
    Poland Lodz
    Yea my ECU is 03G 906 016 EG EDC16U1 maybe is possible itself about Falsh failure ..I must buy adapter 56pin ssop to my programmer and try read bad flash...Check CAN impulse by scope if nothing ECU not working...Here you are pinout EDC
  17. The Following User Says Thank You to t77 For This Useful Post:
    cole_mcs (7th April, 2014)
  18. #15
    will try that thx
