Page 2 of 2 FirstFirst 12
Results 16 to 20 of 20
  1. #16
    V.I.P. Member mdt's Avatar
    Feb 2009
    bolton, north-west. uk
    Quote Originally Posted by yerman View Post
    i was going to try and use a multi LNB setup with it, but now thinking it would be too much hassle
    Im now looking at a Triax 80cm Dish
    Genuine Triax TD78 High Quality Satellite Dish 78cm (80cm) Folding Arm Bracket | eBay
    And a Multi LNB Holder
    TRIAX TD MULTIBLOCK MULTI LNB HOLDER | eBay
    I aim to pickup
    13.0E - 19.2E - 28.2E
    are these hard to setup?
    Also i want your recommendations on LNB's
    thanks in advance
    the best lnb,s for normal money today are the inverto black ultra series although the smart titaniums are excellent also, regards mdt
    DM800HDSE SIM 2.10. SSL84D OPEN-ATV ORBITAL 80CM/DARK MOTOR/IBU/53E-30W
  2. #17
    Ok all ordered,
    As i look at the dish when fitted, am I right in thinking it will be, starting from left:
    i will not be using first LNB holder
    1st LNB - 28.2E
    2nd LNB - 19.2E
    3rd LNB - 13.0E
    As signal is reflected off the dish
    Also what noise level LNB's do I need? ( 0.1db, 0.3db etc )
    Is there any problems with focal lenth?
    Based in Mid East of Ireland
    Great site this is, everyone willing to help each other out
  3. #18
    Feb 2009
    Ok all ordered,
    1st LNB - 28.2E
    2nd LNB - 19.2E
    3rd LNB - 13.0E
    take no notice of the noise levels as they are taken from just 1 point in the spectrum but i think inverto and smart are both 0.1db anyway... as regards focal length just ajust the position backwards/forwards and clockwise/anticlockwise(skew)and tighten with the highest ss/sq reading. i dont know for sure as i am in north-west uk but you could be right on the limit of reception with a td78 for a 3 lnb 15 degree spread in your location but im sure maybe @potrobber could give you a accurate reception report as he,s from your neck of the woods, regards mdt
  4. #19
    Jun 2009
    deleted post as just seen MDT has put you straight.
  5. #20
    all setup and going well, cheers lads
