Results 1 to 2 of 2
    Junior Member planktom's Avatar
    Nov 2011
    black forest
    Default reading TMS370 with upa
    good morning
    can anyone show me how to wire the upa to tms 370 ?
    i?ve got an upa-usb with adapters but my soldering skills are very bad and i only have an "lpg-fired soldering iron"
    so i don?t wanna remove the tms from the pcb or even lifting pins !
    as i?m only working on my own car its to expensive to buy
    "arthurs adapter set" and the one from tek-tronics isn?t available at the moment
    the upa tms adapter board has an "connector for additional adapters" but how have i to wire this to an tms(some here say its tms370c702 others say Its tms370c*32 third ones says It doesnt really matter which one you select as most of them have the eeprom started at the same addresses....) from a
    vw immo2 box 6H0 953 257 B.....
    sorry but the upa isn?t really designed for noobs as i am one of them.i think by using the adapter and wire it to the tms it should read in cicuit? the "connections" shown in upa soft are
    weird...should be the connections from the 9pin comport connector if you don?t use the adapter-pcb?and the pictures in help file are showing completely connected wiring....i think i need only somne of them ?
    i measured the pins to the additional connector but how to connect ? e.g.what is "eds" ? its not described in the tms datasheet from texas instruments.....a lot of questions,i know,but probably someone could help me ?
    thanks in advance
    greets : tom
    "Sent from my iPhone"
    ...made of rare metals 90% coming from businesses using slaves and children to reduce the ores
    DK Veteran mburu's Avatar
    Sep 2010
    Quote Originally Posted by planktom View Post
    good morning
    thanks in advance
    just use X-prog m it suitable...
