Results 1 to 11 of 11
    DK Veteran Poptest's Avatar
    Sep 2010
    Default Series 60 fuel pressure during cranking
    Hello DK,
    I'm now working on a Detroit Diesel Series 60 with a hard start problem. Cranking time is about 10 seconds. Please share required fuel feed pressure while cranking and at low idle.
    Thanks in advance
    Sep 2010
    I don't know the fuel specs off hand but I'd start by looking for a fuel line that might be leaking/ sucking air
    DK Veteran mondao's Avatar
    Quote Originally Posted by Poptest View Post
    Hello DK,
    Thanks in advance
    Detroit Diesel Power Service Literature - May 2002
    If you intend to use this information to impress your friends, leave it
    and grow up!
    Feb 2012
    those didnot work, can do you help?
    Quote Originally Posted by doit64 View Post
    only works with the browser IE, perhaps that is your problem?
    and grow up!
    Member Dieselhawk's Avatar
    The series 60 will start with very minimal fuel pressure. Usually as soon as you see something on the gauge they will start. They will idle with 10psi. Best to try running the pump straight out of a drum of diesel. Also run return into a bucket and check for air bubbles. I had one today that took about 10 seconds to start which turned out to be a leaking injector but you will know this as the oil level goes up.
    DK Veteran ddmech's Avatar
    Feb 2011
    middle of nowhere usa
    Is it a ddec 4 or 5.The ddec 5 will crank with almost no pressure.N3 injectors.Ddec 4 will crank with about 5 psi.
    Apr 2012
    There is a check valve in the fuel return line out of the rear of the cylinder head, the upper port is the return. Sometimes the valve is at the head, sometimes it is about 12-18" down the line. If it fails, you will lose fuel prime and you will have long cranking times. Remove the check valve and try to blow air in both directions. Sometimes, fuel injectors will leak externally, from either the body o-rings or from the solenoids. Check your engine oil level and condition. High level and clean oil might indicate fuel leakage. You can, with the right tools and ingenuity, remove the rocker cover, pressurize the fuel system, and watch fuel leak from the injectors. Good luck!
    Newbie Posey's Avatar
    Australia
    Quote Originally Posted by Jeffinator View Post
    ^^ This
    If a 60 series is hard to crank always replace the check valve on the rear of the head straight up
    Hope this solves your issue
    Apr 2012
    Don't forget, the 90 degree fitting in the return port is a restrictive fitting, it is drilled as an orifice to create the required fuel pressure. Removing or altering the fitting can and will result in low fuel pressure and poor running. Unless you know what you're doing........
    DK Veteran mathura's Avatar
    Aug 2011
    I have a no start probelm with a Detroit 60 series engine mounted in a Freightliner.
    It is throwing fault code 42 too few SRS (missing SRS), replaced SRS sensor, Checked wiring to sensor, checked power supply and ignition power. Everything OK but engine refueses to start, however it runs on starting fluid. When barring the engine it seems kind of free, little effort is required.
    What else should I check. Engine cranking at 175-185 rpm, batteries new and all grounds good.
