    Default How to add astra 28.2e satellite - skybox f3 satellite?
    hi all, using skybox f3 receiver with a sky dish facing astra 28.2e.
    i cannot see the satellite in the satellite list, so i will need to add 28.2 satellite info. please help with the info i need to add.
    satellite list> add > add satellite window
    name =
    longitude = (DO I ADD MY PERSONAL LONGITUDE
    lnb frequency =
    Diseqc1.0 =
    diseqc1.1 =
    22k =
    motor type =
    i think i understand most of it, but what do i enter for lnb frequency????
    thanks in advance. regards kaisar
    Nov 2010
    Are you sure its not there, I just set one up the other day and its there for you to choose.
    Maybe you are not scrolling down or press the right arrow button and you should see it.
    That was with the pre installed firmware that came on it.
    Jul 2008
    I have the same issue, I have just purchased a Skybox F3 and 28.2 is not part of he satellite list.
    It starts with E68.5 all the way through to W177.0
    The firmware on this box is 3601HD_31_10_2012_0B39
    Please help!
    DK Veteran nibblitz's Avatar
    28.2e is probably in your satellite list, but maybe its named something you dont recognise... Maybe Eurobird1...
    But why dont you download a channel list from here instead..
    Dec 2012
    I can't see it listed on mine either but did a scan on another one listed and most channels have appeared
    Dec 2012
    easiest way is to download channel list. if you got a new box, you can still do it with the whole list of satellites. just choose the 28.2 astra sat, select it, and then do a blind scan. should work
