Results 1 to 7 of 7
    bangreno's Avatar
    Oct 2011
    Default Opel Vectra B Immobiliser Relay Voltage Low
    Today I programmed a Vectra B transponder with OP Com.
    All is ok, but remain two DTC 00021 : Immobiliser Relay Voltage Low and P1503 : Immobiliser Wrong Signal.
    Please can somebody can help to locate this Relay , and what's the mean of 'Wrong Signal'.
    leandroks's Avatar
    Brazil
    when the immo receives a low voltage it not necessarily is a relay, it can be a lack of negative, have a look on the lighter, the negative there is the same as the immo, if there a problem there the immo also ll be afeccted... cheers
    Shmortz's Avatar
    in the middle of nowhere
    opel immo 2 have two relay outputs, I have not seen never relays connected to immo on opel, try to change coding on immo with opcom. P1503 can be stored if key is wrong, try to reset ECU and program immo function again, then program key again and verify that VIN match in immo and ECU
    bangreno's Avatar
    Oct 2011
    Quote Originally Posted by Shmortz View Post
    Ok, will try again.
    bangreno's Avatar
    Oct 2011
    ECU Programming function is grayed.
    VIN is ok in both Immo and ECU. Erased all transponders keys , reprogrammed key #1 , the only fault on immo is Low Voltage.
    I'm using OPM 08/2010
    Shmortz's Avatar
    look in immo programming or special functions and disable relay outputs...
    bangreno's Avatar
    Oct 2011
    No disable functions. But I think problem maybe wiring between Vehicle Speed Sensor-Immobiliser-ECU.
    I read someware that immo signal is routed with Speed sensor signal wire , Pease can you confirm and help me to locate this wiring ways.
