Results 1 to 10 of 10
    DK Veteran m3m5's Avatar
    Default Peugeot 206 9652275980 error P0801
    Mates i need help, i'm working 2 days on car and I can't find error.
    P 206 year 2004
    unit 9652275980 Autoliv 602327300
    rgb acu3 v 06 c
    5e ga7d 0673271h c4
    light airbag always on. error code P0801 circuit open detoner 1 airbag driver
    I have change com2000 by the same reference but used. light on the same error.
    Anyone has schematic airbag for this car???
    I posted dump of unit
    thanks!!!!
    Excuse my english, it's poor
    vuno01's Avatar
    Europe
    use autodata or similar and theres a schematic
    Apr 2012
    Quote Originally Posted by m3m5 View Post
    P 206 year 2004
    rgb acu3 v 06 c
    5e ga7d 0673271h c4
    thanks!!!!
    look check for good contact to the ECU airbag,test 4 wires disconnected from ecu to airbag.
    morfej's Avatar
    There is something that could cause what you describe.
    br
    Vuno 01 I can't find the same schematic in autodata, vivid and tolerance. this car has got com2000 all schematic are normal ring.
    AGS, we tested 4 wires in airbag conectors to airbag ecu, are good, between them we saw with polymeter in mode diode has got continuity.
    Morfej, i'm going to try your dump. Maybe those differents bytes are present error???
    I'm thinking open airbag driver?? Could check this part with polymeter??
    thanks!
    not mate don't work this dump. the same error.
    i have change driver airbag by another used, but the same error.
    I don't know why you remove driver airbag read fails and always said
    P0801 drivers module trigger open circuit permanent fault
    Anyone knows how can check com2000?
    chacarita's Avatar
    Argentina
    easy way put a 2.5 ohm beafore com2000 if the error dont go sendme a vin and i will send you wiring , do you have pp2000? if you haveit you can disable detoner using telecode
    well, at the end com2000 broke.
    resistor 2,5omhs before com2000 light off errors clean
    com 2000 connect, 2,5 ohms in blue conector light off, move steering wheel light on.
    if disable detoner, in case of accident ??? what's happen???
    chacarita's Avatar
    Argentina
    well if is detoner one airbag only work in high crash if is a low crash dont work , when ecu airbag detect a crash is is low crash then ignition detoner1, but if this a big crash then ecu send to ignition detoner 1 and 2, so if you want to be sure replace or repair com2000, if you dont now you know what happend
    Apr 2012
    problem is in com2000 flex wire broken,you need solder or replace flex inside com2000
