Results 1 to 15 of 15
    DK Veteran mburu's Avatar
    Sep 2010
    Default vas 5054a software not working in Windows 7
    Hi buddies, error message ADM Class Not registered once i load VAS 5054a n the two icons vehicle self-diag n OBD are not there, have correctly entered workshop dealership identifier. please help......
    miha99's Avatar
    EU
    Please use XP desktop or Virtual machine to run VAS on your system.
    Sep 2010
    Quote Originally Posted by miha99 View Post
    Hi, but in windows XP does not need virtual machine only needs installation of java software.....
    Jun 2012
    Hello Mates,
    VAS5054 does'nt work on Windows7.
    Miha99 is maybe right.
    Using for VM ware or Virtual box on Winodows7 ..It works no problem.
    Good luck
    Maartinj's Avatar
    Nov 2010
    VAS 19.01.01 working perfect on Win7 32BIt. i have 2 - one in main system 2nd one in VMware. Post a screen from your VAS error (details)
    Sep 2010
    Before loading it debugs with that error msg.....
    EU
    Work under WIN7 32bit without VMware.
    Not work under WIN7 64bit.
    impactops's Avatar
    Quote Originally Posted by Raptor181 View Post
    Also works in Win7 64bit
    Impactops
    Maartinj's Avatar
    Nov 2010
    double succes
    Sep 2010
    Quote Originally Posted by impactops View Post
    Impactops
    Do i need to install VM n does version differ(professional, home edition, ultimate n starter )???????
    impactops's Avatar
    Quote Originally Posted by mburu View Post
    No VM, i have it installed on ultimate.The vas5054 driver is the only real issue which can be resolved
    Impactops
    Sep 2010
    Impactops
    Al try n post result......thanx
  13. #13
    Can anybody help me with the driver for vas5054 in win7, I installed vas v19 on win7 and it is working in compatibility mode for xp sp2 and now can not install driver because I do not have it. Can You help me with this. Thank You in advance...
  14. #14
    Dec 2016
    di you solve your problem because i have same problem i install vas-pc in windows 7 32 bit
    but can't install drivers
    any help
  15. #15
    Apr 2016
    Argentina
    You go 5054 with your software odis 2.0 works perfectly on windows 7 32bit, I've got it going and it works great
