Results 1 to 9 of 9
    Jun 2012
    Default Opel Security Code OP-COM AutoScanner
    Hello everyone!
    A. I can give for free:
    1. OP-COM - program, which I bought, for diagnostics of Opel
    2. AutoScannerOpel - program, which I hardly found in Internet, for diagnostics of Opel
    B. I'm (desperately) looking for the Security Code for my car (Opel Vectra B 2.0 DTi; engine X20DTH) in order to be able to use on 100% the options of the above mentioned OP-COM diagnostic software. The car is second hand and (of course) i do not have the Pass Card which contains the Security Code (I had such one with my previous car).
    Thanks in advance. Looking forward to get in contact with you dear friends.
    meteor80's Avatar
    You need to go to local OPEL dealer and they will give You pass.
    Not for free of course and only if You are a owner.
    Work is a primitive way to spend Your free time.
    F.Kiepski.
    Jun 2012
    Thank you for the advice meteor80.
    The option you suggest me is quite familiar to me since the beginning of my problem.
    What bothers me is that if the official opel guys can do that, that means that there is some way. And I wanted to find what that way is. Cost of course is the other side of the card.
    Also I'm wondering of the following:
    If I had the Pass Card with the Security Code, BUT if the previous owner had changed that Security Code with some other one. Than the Security Code on the Pass Card would be old, i.e. not valid, right? Ok, that in such case I'm wondering how the opel guys could give me valid Security Code? The possible answer might be that they have some kind of Security Code Generator, otherwise it would be logical that they also could not be able to help me, which I don't believe.
    Yes, I am the owner of the car. According to it's documents i am the 3-th or 4-th owner after 2-3 companies (firms). By the way by documents I am also owner of other opel car (Corsa D Tiptronic 1.2 gasoline 2002y.) which actually the parents of my wife (thay are all foreigners) bought, so that car is aslo without Pass Card / Security Code ... So my issue is not single
    Shmortz's Avatar
    in the middle of nowhere
    you don't need pin code, in your car it is used only for immo functions, and can be extracted from immo box MCU dump...
    drakov's Avatar
    Aug 2008
    The dealer only has the original pin that came with the car, if it has been changed they will still give you the original pin and still charge you, they have no calculator they apply for security pass via a 3rd party who then fax back the Original codes for that car... if the code has been changed you read chip as stated above and convert using software or you pay someone with the tools and knowledge to do it
    Check out The Number 1 Resource for all Automotive Software with a lot of patience you like me will find what you need...
    Dec 2012
    Hello! can i catch the pin from autoscanner?
    Jun 2011
    Northamptonshire, UK
    You could get carprog and then that can retrieve a lot of opel codes diagnosticly from the ecu
    Music73
    Mar 2013
    I ve also read somewhere you can get the code from the dump try youtube but I m new to all this just waiting to get my opcom
    Dec 2011
    VISIT HOW TO READ OPEL PIN CODE ON YOUTUBE
