    Top Poster + pnj's Avatar
    DK
    Default BMW E34 518i ECU SWAP 0 261 203 280
    Need to swap ECU in the abowe but have problem to figure out if possible "on the table" or not ?
    Seems no seperate eep
    Any one have idear for this one ?
    Apr 2011
    eeprom is AM27C256 or AM27C512. just switch flash.
    DK
    Ic it is old type UV Eeprom offcourse
    Is the flash the 28pin soic B58322 below the UVeeprom ?
    Apr 2011
    no, all data is in uv flash
    DK
    OK Thanks
    This mean just to swap the big thing in socket ?
    Apr 2011
    yes, if you have the same no.
    you can also read flash and write isn from old ecu, and make sync with gt1, dis, pa soft.
