hi for online version 7.3 the price is update
he work very good thanks for job
Who can help me how to get to the serial number. Thanks in advance. Sorry for my bad english.
regards,
Freddy
Groeten Fred.
I have installed ETKA but I have a problem with the installation of the hardlock. I'm using Win 7 64 bit. I have read the explanation of this item. which folder can I find the crack of the hasp Drivers.exe? Should I still crack downloaden.sorry for my bad english
regards Freddy
Groeten Fred.
I need serial 7.3 etka plus.
Thanks.
I want the update tool V1.9 to use the update from 1000 for VW and Audi to install. But update tool does not work. The old version V1.7 to 1000 worked fine. What am I doing wrong? Sorry for my bad english.
Freddy
Groeten Fred.
1. Open ETKA 7.4, then close ETKA
2. Apply Update Fix v1.7
3. Copy/install Updates only up to the 1001 for AUDI & VW to the respective folders. If you use a online tool, beford open ETKA, remove updates after 1001
4. Open ETKA 7.4, apply updates, then close ETKA
5. Apply Update Fix v2.1, ETKA 7.4 auto open (Confirme if AUDI & VW are updates 1001). If yes close ETKA. You can go to the next step.
6. Copy/install updates after 1001 (currently 1003)
7. Open ETKA 7.4, apply updates, then close ETKA
8. Now, you can open ETKA (7.3 or 7.4)
I'm Portuguese, so i apologize for my very bad English.
OTE=Rui Aguiar;2223681]1. Open ETKA 7.4, then close ETKA
8. Now, you can open ETKA (7.3 or 7.4)[/QUOTE]
In which folder can i update's add / remove? When I execute an update, I get the message " see view ". If I run the update Seat and Skode wiht the tool V1.7 runs it in ETKA the old version .Wats is the problem.
Groeten Fred.
Hello, i need the install key serial number please. Cheers!
C:\ETKA\DATA\AU\Update
C:\ETKA\DATA\VW\Update
freddy11 (17th February, 2014)
I mean if the updates are already installed. I have the following problem. Update from VW, AUDI 1000 I can not update more programs. I get the message of ETKA "This data update can only be processed by the current of version of ETKA 7.4
regards,
Freddy
Groeten Fred.
I want to first say thank you to OP 4 providing excellent softwares. I installed program and have updated according to instructions.
I then created a vin.txt file again according to instructions. But when I go search for the vin in etka 7.3 I get this error
Maybe someone knows how to help please.
Thank You
Many thanks for replying. Now opening ETKA 7.4 I get this error.
I un-installed program and ran a registry cleaner to be sure.
Install software from mounted ISO.
Run ETKA 7.4 and get error shown after included price updates run.
Apply ETKA 7.X PLUS 09-2013.UPDATE.FIX.
Use Auto Update By MariusMilanezu tool to get updates and then I move them to appropriate folders.
Open ETKA 7.4 again and it starts to process some updates but doesn't finish all.
Leaves Read-Only folder named Prog1_$Upd$ under C:\ETKA
Have done the above procedure all last night and today and still the same errors.
Also please where to find Update Fix v1.7 ??
Inside this file ETKA 7.X PLUS 09-2013.UPDATE.FIX.txt before (v1.7)
Here step by step instructions as it should have done:
1. If you have updates of AUDI & VW lower then 1001, Open ETKA 7.4, then close ETKA
3. Copy/install all upadates VW/AUDI 982-1001 together with the SE 508-527 and SK 514-533 to the respective folders.
If you use a online tool, beford open ETKA, remove updates after 1001 for VW/AUDI, SE 527 and SK 533 (C:\ETKA\DATA\xx\Update)
5. Apply Update Fix v2.1, ETKA 7.4 auto open (Confirme if AUDI & VW are updates 1001, SE 527 and SK 533).
6. Copy/install all new updates for all brands
9. From now on, before Copy/install Updates or using any Online-Update tools,
first RUN and CLOSE ETKA 7.4, Copy/install the new updates. Open ONLY ETKA 7.4 to aplly new Updates
