Results 1 to 4 of 4
    Jul 2012
    Default Scanning issue with new Dreambox 7025+
    Hi Gurus,
    I need a help in configuring new 7025+ as just replaced with previous one. This box having both DVB-C tuners while in the old one, both were DVB-S. Issue is that when I try to scan, it simply failed to find used transponders.
    I live in Reading, UK and using below settings to scan:
    configuration mode = enabled
    used service scan type = Frequency steps
    frequency scan step size = 01000
    scan qam16 - no
    scan qam32 = no
    scan qam64 = yes
    scan qam128 = no
    scan qam256 = no
    scan SR6900 = no
    scan SR6875 = no
    scan additional SR = 6952
    scan additional SR = 6887
    In my previous box, I had below settings:
    frequency 11836
    astra 19.2
    symbol rate 27500
    Even after setting the above symbol rate, its same issue. Couldn't use this frequency because of limitation of DVB-C.
    Will appreciate any help.
    Cheers.
    Jul 2012
    Any one can make any comment / suggestion ?
    Thanks in advance.
    GastonJ's Avatar
    "This box having both DVB-C " You need DVB-S for satellite. C is for cable. You need 2 new tuners.
    Jul 2012
    Many Thanks.
