Results 1 to 9 of 9
    Top Poster bekamon's Avatar
    Mar 2009
    Default ISUZU NPR FAULT DTC 340 HELP!!!
    I have in my shop, a truck isuzu npr 2005 with 6hk1 motor, a fault DTC 340, I checked wiring, negative, voltage reference, I have changed sensors, but when I connect the scanner no recognizes the camshaft and the value is never present on the scanner, someone has had this problem??
    Jun 2012
    I''m not sure what code 340 is off of the top of my head, but it seems you are saying it is the camshaft timing sensor. Have you checked the terminals in the ECU? Also have you made sure that there isn't an issue with the tone wheel on the cam?
    Mar 2009
    Quote Originally Posted by eric486 View Post
    Thanks for your interest friend, if you check all the wiring from the sensor to the ecm harness.
    all I can think is that this bad ECM and reprogramming need to be
    so far as many engines I've seen with this fault
    Jun 2012
    There is a TSB for the wiring on the cam sensor, I'll try to upload it when I get a chance if you are still working on this truck.
    Mar 2009
    upload it please, I'm still with the truck
    Jun 2012
    Here you go! Hopefully this can help you out a bit.
    Just noticed this is for a 4hk1, sorry, I guess I should have read a little more carefully, I just looked up NPR service bulletins...
    Mar 2009
    this engine is a 4hk1
    thanks friend for the tbs, I've checked continuity with a multimeter each and every good, I will try disassembling the harness to review it
    Jun 2012
    Okay, I noticed in your first post you said you had a 6hk1. That is where my confusion came from then.
    Mar 2009
    I sorry you are rigth, is not a 6hk1, the real engine is a 4hk1
