Page 442 of 462 FirstFirst ... 342392432437438439440441442443444445446447452 ... LastLast
Results 6,616 to 6,630 of 6926
  1. #6616
    Nov 2018
    Rotterdam
    Hi all, I just did the mileage on a Discovery 2 with a Digiprog 3. First I did the odometer with cable 1 with success and then I tried to do the BCU with cable 35 and solderd all the wires correctly but the Digiprog doesn’t seem to connect the BCU and shows an error message “No bootmode”. I have done the odometer and BCU of another discovery 2 the same way with the same Digiprog 3 unit with success. Is it possible that my digiprog unit is broken or might it be the cable ? Please help.
  2. #6617
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Always possible and presume you mean Freelander 2
  3. #6618
    Nov 2018
    Rotterdam
    Quote Originally Posted by teerak2uk View Post
    No it is a Land Rover Discovery 2 Td5
  4. #6619
    rtbdiagnostic's Avatar
    May 2015
    My Tool Room
    Cas 2 should be a white box ...
    'If I helped, please click Thanks +Reputation.. !'
  5. #6620
    Dec 2018
    hi all,
    digiprog is easy to use on peugeot 407 from 2004 ?
  6. #6621
    cheero's Avatar
    Czech Republic
    beste is more hardawre
    Digiprog read direct eeprom from dash and read direct eeprom from BSI
    more hardware read BSI via OBD and dash direct via eeprom
    ++++ GOOD WORK ? + ++++
    FIAT EMEA 7inch, Ford Sanyo, DELPHI Chrysler Jeep Dodge, DELPHI Volvo GMC Renault, Ford FIC, Fiat Turkey, Ford V Series Calc, Fiat Continental VP1 VP2 Calc, Opel Delco CDR500 & CDR2005 Calc, Mercedes Alpine Calc, Jaguar Alpine Calc, Fiat Daiichi Calc, Delphi Famar Fueguina Calc, Renault Calc, Dacia Calc, Grundig oldtimer Calc, Chrysler Jeep Dodge Panasonic Harman Becker Alpine Continental Calc, Blaupunkt Calc, Philips oldtimer Calc, Audi Aisin RNS-E Calc ....
  7. #6622
    Nov 2018
    Rotterdam
    Hi all, I did the mileage on a Discovery 2 with a Digiprog 3. First I did the odometer with cable 1 with success and then I tried to do the BCU with cable 35 and solderd all the wires correctly but the Digiprog doesn’t seem to connect the BCU and shows an error message “No bootmode”. I have done the odometer and BCU of another discovery 2 the same way with the same Digiprog 3 unit with success. Is it possible that my digiprog unit is broken or might it be the cable ? Please help.IMG_5425.jpg
  8. #6623
    Dec 2018
    password plz
  9. #6624
    Feb 2017
    Baltic
    Quote Originally Posted by rtbdiagnostic View Post
    dont need to take apart car to tell, if car has blade key then cas2, if smart key then cas3, simple
  10. The Following User Says Thank You to mikkhh For This Useful Post:
    rtbdiagnostic (3rd January, 2019)
  11. #6625
    May 2015
    My Tool Room
    2016 ford torneo custom with nec+95320 works good with digiprog 3 - even when programming in circuit by clipping onto eeprom no hassles
  12. The Following 2 Users Say Thank You to rtbdiagnostic For This Useful Post:
    antenor (8th January, 2019), bersch8688 (8th January, 2019)
  13. #6626
    aem's Avatar
    Jun 2014
    snowboarding on the mountain
    audi Q5 2011 digi 4.94 obd read ok write ok 30 minutes
    FILE SERVICE
    REMAP+ dpf-egr-vsa-scr-lambda...cars/buses/agriculture
    Genuine WinOLS user
  14. #6627
    Mar 2013
    Europe
    Digiprog 4.94
    Audi Q7 2014 (NOT NEW DASH)
    OBD work Perfect
  15. #6628
    Jan 2019
    Just completed my first Digiprog 3 odometer correction.
    2006 Dodge magnum. Mission Complete.
  16. #6629
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Quote Originally Posted by mikkhh View Post
    So what cas would this have
  17. #6630
    Jan 2019
    I did not read the rules, if i'm doing something wrong i apologize. hopefully this doesn't cause a system melt down.
    Digiprog 3 v4.94 CD Data all PDF,s photos and Pin-outs are within.
    https://filehost.net/819d8996c0826d22
  18. The Following User Says Thank You to triko03 For This Useful Post:
    Adamdad (30th April, 2019)
