Results 1 to 15 of 18
    romania
    Default problems carprog china,USB port blocking
    I bought carprod of china, but I have a problem with it.after introducing the USB interface. program recognizes series, the interface. If you want to read an EPROM, an error message appears."No device attached".After this message, USB ports are blocked, until restart the computer.I tried on another computer, but just as...
    autocargo's Avatar
    Open your carprog interface and check usb socket solderings. Some of them not properly soldered. Also you can try and change usb cable with known working one. Good luck. Keep us posted.
    romania
    Thank you for your promptness, Tomorrow try this
    romania
    I think it was the problem, now it works well .... for now
    autocargo's Avatar
    Glad you sorted it...Was it soldering or USB cable? Does yours reads eeproms 24c02/04 ?
    romania
    I replaced the USB cable with a new one.I tried to read memory 24c/02, but externally, it reads and writes. not tried in the circuit, because not at hand now a montage of 24c02.The earliest opportunity, inform you if read in circuit, Thanks!
    autocargo's Avatar
    if you can make and upload some good quality photos of carprog main board wold be really nice, mine doesn't read 24cxx.
    May 2009
    yes please mine dont read 24cxx
    martij976's Avatar
    Quote Originally Posted by daewo97 View Post
    PLEASE buy an original carprog and U have not these problems anymore.
    HOW DIFFICULT IS TO UNDERSTAND ???????????????????
    martij976's Avatar
    Quote Originally Posted by morito View Post
    Buy original !!
    martij976's Avatar
    Quote Originally Posted by autocargo View Post
    Mine ORIGINAL reads 24cxx without questioning !!
    martij976's Avatar
    Why You guys do this???
    Buying china crap and than crying? Good for You ! You should already know, that china crap won't help You!! Only took Your money away! Here on DK is plenty of explains how to avoid being fu*cked by china "brothers"! Just read! And learn!!
  13. #13
    Here you are the high res pictures.
    Mine doesn't read 24cxx (reads 00's) either and doesn't write 93cxx. At 93cxx writing problem, I found that carprog does not pull up wp pin to vdd when writing. All connections are ok. You can solve this by connecting wp pin of 93cxx to vdd.
    24cxx problem is (in my opinion) is mcu software related.
    I measured the waveforms at sda and scl pins. All are ok, slill it reads 00's.
  14. The Following User Says Thank You to nemena For This Useful Post:
    koki (29th September, 2013)
  15. #14
    Bratislava,Slovakia
    Hey, guys.
    Unfortunately for me it became a problem.
    Green light is on, but the PC does not see the USB hardware.
    I changed usb cable, but unfortunately it does not work.
    How to repair?
  16. #15
    romania
    carprog mine, does not want to work,read several times,..... and now the green light flashes, but does not recognize USB interface
