Results 1 to 15 of 18
Thread: T300 reset 2003 Toyota prado diesel euro?
    145
    Default T300 reset 2003 Toyota prado diesel euro?
    Hi m8's
    I have got a Toyota Prado 2003 Diesel European model with all key lost. I would like to know whether I can use T300 or SBB to reset the Immobilizer to accept the new keys.
    Thanks,
    Neverquiet
    achaccha's Avatar
    Nov 2010
    119
    That's right friend, you can program the key using either of the two tools you mention.
    regards
    leandroks's Avatar
    Brazil
    358
    If it wont work post the dump and key logical data and i ll program it for u...
    Nov 2010
    28
    yes u can reset the imm with both programmers.
    145
    Thank you so much friends.
    I have more questions!
    Does the reset procedure require password seed?
    I haven't reset any Toyota immobilizer before.
    achaccha's Avatar
    Nov 2010
    119
    Friend does not ask for password
    proceed to reset with a key in the ignition using t300, after 30 minutes was the key in the ignition is programmed.
    after that the light stays on steadily immo and then have to cycle the key 6 times.
    open-close-open-close the swicht for 6 times and then the light switch off and the engine starts.
    luck
    145
    Quote Originally Posted by leandroks View Post
    Hi leandroks,
    I still cannot get the immo reset, so I got the immo off.
    Please help me to add the two key logic to the 93c56.
    The key logic of the two Master Keys are as bellow
    Key 1:
    Pg1 52
    Pg2 56
    Pg3 EE 49 C1 11
    Pg4 E083BEB490
    Key 2:
    Pg1 B2
    Pg2 65
    Pg3 09 00 78 16
    Pg4 1D23FE47C5
    Thank you so much!
    bram380's Avatar
    Indonesia +628153111774
    484
    Bad dump, try again read eprom 93c56 from ecu & 93c66 from immo box.
    Some one will add key into these dump.
    145
    Quote Originally Posted by bram380 View Post
    What should I do when I got a bad dump,
    I read it from a GQ-4X, and keep getting the same result.
    Does that mean the chip is bad?
    I only got it off the ECU,
    Please tell me where is IMMO Box is on the 2003 Land Cruiser
    bram380's Avatar
    484
    see image for immo box location.
    item no.3 is immo_box 89780-60220
    Key data stored at immo box.
    How many active keys stored at ecu_box.
    You sholud to program immo & ecu.
    bram380's Avatar
    484
    Default LC Prado 2003 EURO
    Sorry mate,
    for LC Prado 2003 Euro market see here:
    145
    I feel so sorry that I cannot find the Immo box.
    I will put the info here
    VIN number
    JTEBY25J100002429
    According to the vin decoder this vehicle is 2002
    ECU: 89666-60840
    I got the ecu from the passenger side at the lower right.
    It is different from the diagram above.
    Please tell me where is the immo box.
    thanks.
  13. #13
    bram380's Avatar
    484
    Reference JTEBY25J100002429:
  14. #14
    145
    Finally I got the immo off.
    I got the dump from the immo 93c66: in file
    93c66b dump prado 2003.zip
    The dump I got from the ecu is a bad dump in file:
    Prado 2003 93c56.zip
    I have also found two virgin dump file for Prado 2003 in flie:
    Imo + ecu virgin.rar
    Since the dump I have go from the ecu is corrupted.
    Should I just use the virgin dumps and try?
    or should I wait for your help to get the keys written on to the dumps.
  15. The Following User Says Thank You to neverquiet For This Useful Post:
    Pablitocrpz (6th August, 2020)
  16. #15
    bram380's Avatar
    484
    try these dump with keys:
    Key 1:
    Pg1 52
    Pg2 56
    Pg3 EE 49 C1 11
    Key 2:
    Pg1 B2
    Pg2 65
    Pg3 09 00 78 16
