Results 1 to 12 of 12
    Default Daewoo Lanos 1.5 Immo off
    Hy, i lost the keys, replaced locks and got key and immo box from scrapyard, but there was no ECU, is there any way to immo of this?
    Its 1.5 benzin 8v. Immo box sais 96303500 DPI 7541114.
    THere are no 8 pin eeproms inside just three 17pin eeproms and a big MCU..
    any place to buy a emulator or immo off solution.
    Meat-Head's Avatar
    cool, *TRY* and ONLY a try
    See if the BIG chip is a motorolla HC11 or something. Read the eeprom only, fill with ff
    and then love DK long time.
    What is inside immo box?
    Dunno what s inside the ECU, i cant find it...they say the passenger side in the car..
    the immo box has a big square MCU or plcc-vdo5596 IM 40303. and there are three 14pin microwire eeproms.
    i dont have tools to read any, i can only read 8 pin soics.
    Meat-Head's Avatar
    Quote Originally Posted by ominimicu View Post
    You best get on the blower and
    1) Order a FULL fondoo set
    OR
    2) Whip your flexable friend out and down MVP T300 SBB, whatever you can find down the local fleamarket.
    found the ecu under the seat, it has only one small eeprom 8 pin..read it..and info is all 808080.
    it has a blue double connector
    Fec001's Avatar
    ECU has HC11 MCU but if it has light blue connector you must replace the 27c256 eprom with modified file
    umoussa's Avatar
    Universe
    even if with HC11 modification, it will not work. You need emulator
    ECU Commander Studio?
    Hand in Hand to Protect our Efforts - Stop Hunting Our Work
    >>>>>EBAY SELLERS<<<<<
    I'm not Sharing Passwords!
    Do not argue with an idiot. He will drag you down to his level and beat you with experience
    GB
    can u post the pic of that ecu so i can help u
    lanos got several ecu shape
    GB
    try this dump from 27c and report
    what 2 big characters u have on ecu ??
    Quote Originally Posted by toximatic View Post
    Hi!
    Works, but rpm in dashb oard not work. All the rest runs ok.
    Dec 2011
    Hello dear friends.
    HERE IS a file 95020 can someone help me? immo off
    Deawou Lanos 1.5 delphi-delco
    bursuc's Avatar
    Oct 2011
    inside MCU
    Quote Originally Posted by gabes View Post
    Hello dear friends.
    Nobody knows a solution for this ecu ? with 95020 ?
    Thank you
    Dosen't matter how hard is to repair something as long is made by humans and thinked by humans !
