Results 1 to 10 of 10
    skens's Avatar
    Zagreb,Croatia
    Default power steering OPEL Meriva
    hi
    how to repair power steering OPEL Meriva?????
    delphi,
    soldered all contacts
    thx
    regards
    Please dear members push the button thanks and reputation button(stars)
    do you need help? fill it in !!!
    Model:
    Motor capacity:
    Diesel/Gasoline:
    Production year:
    ECU type and number:
    Memories :
    https://www.digital-kaos.co.uk/forum...63#post1660863
    nederland
    replace the relay
    skens's Avatar
    Zagreb,Croatia
    hi
    tested the relay, is normal!
    You had such a case?
    regards
    Model:
    Motor capacity:
    Diesel/Gasoline:
    Production year:
    Memories :
    Meat-Head's Avatar
    Rumor going around, clearly states there is TWO sets of brushes in the motor, one set fails making it hard to turn one way.
    The grapevine is emmiting noisses that suggest the other problem is steering angle sensor.
    skens's Avatar
    Zagreb,Croatia
    Default opel
    hi
    the diagnosis verified that it is electric. motor! long time no brushes on the motor!
    has a small sensor on the engine
    Model:
    Motor capacity:
    Diesel/Gasoline:
    Production year:
    Memories :
    Meat-Head's Avatar
    confused
    no brushes left, or brushless?
    skens's Avatar
    Zagreb,Croatia
    Default ster
    hi
    no brushes on the motor!!!
    The whole day I play about power steering! calibrated with op-com! doing well 2-3 km,lamp lights up and goes out! if it stays on, I want to establish fault diagnosis, extinguished and no reported bugs!
    regards
    Model:
    Motor capacity:
    Diesel/Gasoline:
    Production year:
    Memories :
    dimitar's Avatar
    Quote Originally Posted by skens View Post
    hi
    regards
    Well drive the car with opcom attached and watch the parameters
    50w Soldering Iron
    Chisel
    Sometimes Hammer
    skens's Avatar
    Zagreb,Croatia
    Default opel
    hi
    I did to op-com, it's quite amazing that it does not report any error! I calibrated the steering wheel, the steering angle 0, moved the steering wheel shows deflection in the + and -! driving lights the lamp esr and after some time it goes!
    regards
    Model:
    Motor capacity:
    Diesel/Gasoline:
    Production year:
    Memories :
    Member demodamota's Avatar
    Aug 2010
    hello , Mr skens do you have repair it ?
    I have one whit the same problem
    best regards
