Results 1 to 12 of 12
    Becoacamba's Avatar
    AnyWhere
    Default pinout immo lucas mazda demio
    hi guys, i need to read this immobox lucas 37AS, i?m using this pinout but have problems with upa IRQ,RXD, anybody can help please, thanks
    Becoacamba's Avatar
    AnyWhere
    Default hi
    fine, I read up irq and rdx pins, someone to guide me with the logic to build a t5 Please
    Quote Originally Posted by Becoacamba View Post
    I think this might be a 8C system and not a T5 with ID 33
    Pin Code - 21776217 This should be your pin code and this system is MANUAL programming
    MAZDA 8C MANUAL KEY PROGRAMMING PROCEDURE
    These vehicles have 8 digit pin code. This pin code can be obtained from dealer or, can be calculated from ECU eeprom dump by the help of Zed-BULL and Zed-Prog.
    The only way to programme keys into these vehicles is manual programming. After 8 digit pin code is obtained, keys can be programmed into the vehicle manually as described below..
    Sample Pin code = 2 8 7 4 3 7 2 3
    First cut the key and put a 8C transponder in it, or you can use the key ordered from dealer.
    Note:With this procedure minimum 2 keys can be programmed.
    1- Give ignition on and off repeatedly 6 times with 1 second delay. After 6th cycle leave the ignition off.
    2- Pats(immobiliser) light on the dashboard will blink fast for 5 minutes.Wait for 5 minutes.
    3- Pats(immobiliser) light will start blinking slowly, now the system is ready for entering pin code manually.
    4- When the pats(immobiliser) light is off, turn ignition on, each blink is counted as 1.
    As in the sample pincode, for the first digit of the pin code, wait for 2 blinks and turn ignition off.
    When the ignition is off after pats(immobiliser) light goes on and off turn ignition on, when the ignition is on, pats(immobiliser) light should blink 8 times(second digit of the pin code) after the 8th blink, when the immo light is off, turn ignition off.
    When the ignition is off after pats(immobiliser) light goes on and off turn ignition on, when the ignition is on, pats(immobiliser) light should blink 7 times(third digit of the pin code) after the 7th blink, when the immo light is off, turn ignition off.
    When the ignition is off, after the pats(immobiliser) light is on and off, turn ignition on, after entering all 8 digits of the pin code, pats(immobiliser) light should stay on solid, when the pats light is on solid turn ignition on, now the pats(immobiliser) light should go off, now turn ignition off and remove the key from ignition.
    Put the second key to the ignition and give ignition on with this key, wait for pats(immobiliser) light to go off, after the light is off turn ignition off and wait for 30 seconds.
    Both keys are ready programmed to start the vehicle.
    NOTE = While entering the pin code manually, when ignition is on, each blink is counted as 1.
    I stand to be corrected any time
  4. The Following 4 Users Say Thank You to shitad For This Useful Post:
    BusCan (20th April, 2021), cklair (15th October, 2014), gordonjairo (20th March, 2014), speedy100 (26th April, 2021)
    Meat-Head's Avatar
    member darwins had one go search
    darwins's Avatar
    UK
    I have never seen a 37AS...
    I have done a 19AS = T5 & 36AS = 8C
    Could yours be a 34AS ? If so this is also 8C
    Go for it. The future is promised to no one
    Becoacamba's Avatar
    AnyWhere
    Default hi
    thanks friend, yes this use 8c, i was try with this method, but I fail to enter programming mode. the LED does not blink fast.
    DK Veteran viejomatius's Avatar
    Jun 2009
    Hello This is your pincode: 21776217
    Use the manual procedure of shitad to program keys
    Remember you must have 2 keys
    Becoacamba's Avatar
    AnyWhere
    thanks, but fail to enter programming mode. the LED does not blink fast.
  10. #9
    Becoacamba's Avatar
    AnyWhere
    Default hi
    who help me to add this key to the dump please
  11. #10
    Becoacamba's Avatar
    AnyWhere
    thanks, alreeady i achive program it
  12. #11
    Nov 2015
    Hi, please can you help me with the irq and rdx pins Ihav similar immobiliser to read. Do I need to lift pins? thanks
  13. #12
    dadal's Avatar
    Aug 2015
    it is possible to make this ecu immo off ???ECU Denso 279700-0451 car mazda demio yr1998
    or
    can I clone immobox to donor ? lucas 28as ,
