Results 1 to 10 of 10
    UK
    Default willem programmer-95040
    hello,sorry if this is posted in the wrong section...but i need to no if the willem can program the 95 family of ic...(micro)...the ic arnt listed on the menu,but im sure ive read somewhere that it can be done....ive got the soic8 adaptor...but i just need to no if it can do the 95 and 90 family..
    thanks in advance
    ION CRISTI's Avatar
    ROMANIA
    its work to program eeprom 95xxx. work fine
    jcgabbi's Avatar
    Brazil
    Yes, 95040 same>> 25040.
    UK
    thanks for the reply...i have checked on the menu,and cannot see 95 listed...i am sure i have seem that to read 95 family,you set willem to 25 family.and read from there...i have tried this,but no joy...
    UK
    thanks for that jcgabbi,i will try and read chips ...can you please tell me if i can read 90 family chips with willem.
    jcgabbi's Avatar
    Brazil
    What "90 family" do you mean? If is 93cXX of course willem does!
    UK
    as you can tell,my experience is not that good with the willem as i am still learning and practising..i have removed a 95040,and tried to read it....but im getting FF.i try to modify it and program it and it programs but gets a erroe at the end,so i think the 95040 is faulty,maybe from removing..
    jcgabbi's Avatar
    Brazil
    My willem I same built and it works fine...
    Try with other god eeprom as 24c02, 93c46, it need read and write fine.
    Test the connections, clear the soic adapter and the device eeprom terminal with alcohol.
    Check the correct Slot to correspondent eeprom in the willem image.
    Regards!
    UK
    thanks for that,i will give it a wipe with alcohol and see what i get...as for the "90 family"....i meant 95 family.now i understand the logic of the menu..
    mexanico1971's Avatar
    portugal
    Default willem pcb soft
    hi ! use this !
    I use this version width my PCB 3.5
    and work very good !
    BR
    good luck
