Can someone conform the location of the cas unit in a mini countryman 2012 ?
Is it under the upper dash panel as like the older models?
Dp3 obd doesn't recognise the software version, so i have to take it out.
is this not also with fem instead of with cas?
Location is the same place as the others , quick strip out not , although its not recognised it could be a version unsupported
All about the Bass
We found it, you were right, the location is the same.
But we had some more troubble strippng it out, the dash panel seems te be hold down by something in the middle ?
the sticker reads cas3, no fem in this one
Have you stripped one out before , I ask invade , there's a million screws holding the decker together
All about the Bass
I did mini's before, some older types 2009, 2010, always stripping out because i didn't had the obd option earlier.
but this is the first time i did a R60.
The dash is totally naked, center console is loose, airbag, the nav screen in the centre is out, left and right ventilation is out, also the big bolts left and right.
i think i have all screws out now, the only thing i'm not sure about if there are srews in the front window ventilation vent.
it seems i can not pull out this vent to have a look.
i can pull the dash up on both sides and if i pull it goes a little bit to the front but it seems to be held back a little in the middle.
Maybe i'm too carefull with it considering this car is only one month old.
yes this is correct.
there are 2 screws in middle air vent what have to be removed.
