Page 24 of 27 FirstFirst ... 14192021222324252627 LastLast
Results 346 to 360 of 405
  1. #346
    Dec 2010
    It magically worked for me yesterday, but after a restart its stopped working. And the loader can no longer unpack the program. CCleaner shows a missing mui reference in the registry in relation to the loader.exe.
    . Wish it would just work!
  2. #347
    UK
    can anyone try and explain why my version seems to get slower and slower the more and more you use it.....im getting to the point wer i want to smash the screen......
    MAGPRO X17--AT-200--SCANMATIC BENCH--PCMFLASH--MITSUBISHI MUT-III---OPENPORT 2 MMC FLASHER
  3. #348
    Sep 2012
    Hello good evening I could make a perfect intalacion winols 2.24. can help, but in return I want you to give me some help using the puzzles, thanks
  4. #349
    Quote Originally Posted by professor View Post
    Try this:
    Unistal WinOLS and delete folders on both program files if exists.
    Download ccleaner and scan/clean your registry from WinOLS reg keys left.
    Restart.
    Install demo. Transfer the wdapi1010.dll & wdapi1100.dll to Windows\System32 and to Windows\SysWOW64 folders.
    Then run winols demo once.
    Close it, remove from both program files the files inside each winols folders (keep the folders but not the contents) and unrar inside those winols the files of the cracked 2.24 version.
    Then on EVC folder in both program files folders extract the loader.
    Run first the loader on Program files and if problem occurs run loader also from Program files (x86) and then again on Program files.
    If not working do a restart and try the loader again.
    Hope it ll work as mine now.
    Not Work... i will try in other PC ...
    I have only a programfiles because my windows is a 32 bit version and i dont have SysWOW64 directory.
    The steps are easy but don't work for me :'(
  5. #350
    Dec 2010
    I'm going back to 1.7, just tried to export a modified file and checksumm problems all over the place despite all plugins being registered. EDC15 ecu, don't want more problems. 1.7 is fine .
  6. #351
    eugen8's Avatar
    Default winols 1.7
    Quote Originally Posted by poxxxy View Post
    your 1.7 doesnt calculate cecksum on edc15
  7. #352
    mexanico1971's Avatar
    portugal
    OK !
    this is the best part !
    I all ready install and uninstall 3 times ! now I have 3 different"s SW , from different"s sources and different"s sizes !
    all them open but one say"s that "is not a ori or is not complete installation "
    other do not load the file and not show anything
    there is no SysWOW64 in XP pro x86 !
    if some one have luck in the processes please put a tutorial !
    thank"s in advance !
    BR
  8. #353
    Senior Member Diagnosticated's Avatar
    Mar 2011
    Quote Originally Posted by mexanico1971 View Post
    OK !
    BR
    Have you tried the link #341. This one worked very easy for me when tested.
    Switch off anitvirus first.
    I used trial reset to clear computer of any armadillo keys.
    Put EVC folder in c:/programs complete with loader etc.
    Click loader once to install registry items.
    Click loader again to run program.
    Link loader to desk top and run from there.
    Instal was very easy and program seems to work ok.
    I did all this with Avast still on as I forgot to turn it off. oops! and it still worked ok.
  9. #354
    portugal
    Default 2.24
    Quote Originally Posted by Diagnosticated View Post
    This is a 2.24 download link from another forum. It worked perfectly on xp when I tried it.
    Program: EVC.rar ??????? ? ?????@Mail.Ru
    Instl Inst: Ols2.24.txt ??????? ? ?????@Mail.Ru
    Very simple to install and run.
    but the 1?st method have a installer and install in C\programas !
    in the instrucions says to put the loader in C\program files !
    but this one don"t create any folder in program files !
    I think I gonna make a break !
    BR
  10. #355
    pt
    even if you manage to install it
    it just doesnt work good,
    only proofes that all whant this but nobody really use it
    or know how to
    this is a big joke fore me and you all are the clowns
  11. #356
    Jun 2012
    La Coru?a - Spain
    Got no problem installing it. Win7 32b.
    I was running OLS 1.12 in this system.
    Rename old C:\Program files\EVC\WinOLS to C:\Program files\EVC\WinOLS_112
    Same with C:\Documments and settings\youruser\My Documents\EVC\WinOLS
    Install the 2.24 running the ols.exe file that come with the download.
    New WinOLS folder appear on c:\program files\EVC
    Unpack loader to C:\program files\EVC
    Copy WDAPI????.DLL files from C:\Program Files\EVC\WinOLS\driver\32on32 to C:\Program Files\EVC\WinOLS
    Run loader twice and you're done.
    I guess if you run x64 OS then need to copy DLL files from 32on64 folder.
    Good luck and thanks to the uploader haris78
    Last edited by camil; 5th November, 2012 at 06:18 PM. Reason: ADDING UPLOADER NAME OF THE WORKING FILE. ;)
  12. #357
    Jun 2012
    La Coru?a - Spain
    @ZECAS
    Don't know why are you angry, maybe could not install it?
    I did, imported all my 1.12 projects without problems and exported some bin to compare results, and seems to work ok at my side.
    Anyway calling clowns to all the members is not fair. Is very unpolite from you. Take a valeriana and calm down, follow instructions in my previous post and try again.
    Nice day.
    Camilo.
  13. #358
    Sep 2010
    for me everything is OK and works perfect in Windows 7 x64.
    But this version is with a small number of checksum files.
    I miss following:
    Checksum for BOSH MSA15 old ECU
    Checksum for PPD 1.x
    and more because in dlls folder there are only 45 files with checksum.
    is there anybody who have this version with more checksum files?
  14. #359
    portugal
    Quote Originally Posted by zecas View Post
    or know how to
    I do not like your attitude ! it is not correct you said !
    we should all respect !
  15. #360
    london
    Quote Originally Posted by vopi View Post
    I miss following:
    I would like siemens ppd as well
