Results 1 to 14 of 14
    szkeptmen's Avatar
    Hungary
    Exclamation Iveco Eurocargo - VCM modul by WABCO
    Can somebody help me to find immo code from dump ?
    Iveco Eurocargo, year 2008, has no immobox.
    Only VCM modul, made by Wabco, inside 95320 eeprom.
    Lost key problem...
    Thanks in advance, szkeptmen
    Polak, wegier dwa bratanki i do szabli i do szklanki
    keygargoil's Avatar
    Quote Originally Posted by szkeptmen View Post
    Lost key problem...
    this should have either a small black immo box near the left of the column or bsi side of glove box
    szkeptmen's Avatar
    Hungary
    Default Iveco Eurocargo - VCM modul by WABCO
    Quote Originally Posted by keygargoil View Post
    No, it hasn't these boxes.
    The immo reader coil goes directly to this VCM modul.
    No immobox, no BSI, the OBD connector wires from this modul !!! ( I know the older Iveco trucks.)
    I never seen it before.
    keygargoil's Avatar
    Lost key problem...
    do you have a picture of it
    szkeptmen's Avatar
    Hungary
    Default Iveco Eurocargo - VCM modul by WABCO ?
    Of course...
    szkeptmen's Avatar
    Hungary
    Nobody can help me ?
    This truck from year 2008... not too new, I think.
    keygargoil's Avatar
    what id is your key is it from the dealer
    szkeptmen's Avatar
    Hungary
    Key ID48 (Magic II)
    The dealer asks 230 euro for the keycard only !
    (mechanical/key cutting and an immo code)
    Very expensive... only card...
    Jun 2012
    Send me VIN on PW.
    keygargoil's Avatar
    Key ID48 (Magic II)
    did you get the pin code for it looking through your dump there are a few possible pin codes
    Aug 2013
    I have also wabco unit
    The key reader goes to bsi and 24c256 big eep.
    In wabco is 25lc640.
    I'm not completely sure what I need to read. Dealer key I'm told is id62. 2007 iveco euro cargo but newer model than 2001 to 2007. Any help? Thanks.
    Feb 2014
    Read the 25lc640 and use a original dealer key. Tango has the key maker
  13. #13
    ecuremap1's Avatar
    Oct 2012
    Quote Originally Posted by doolittle View Post
    can be used key or not?
    If I Help You Please Rep + Thanks ME
  14. #14
    KARLOVE POŚLADY
    Hi!
    I have similar problem, Iveco Wabco vcm, truck cranking, but not start, fault in vcm B9 -immo or component faulty, truck start on emergency pin code.
    I check the key by Tango its ok ( Tango give me the pin code), VCM sending reading frame to transponder antena as well. Its that truck loose synchro between vcm and engine ecu? There are no CAN Bus faults.
    Regards:
    Bob
