Results 1 to 15 of 19
    May 2008
    Default tuxbox commander
    where i find tuxbox commander.
    Apr 2008
    Quote Originally Posted by papairwin View Post
    That's Plug-In,
    Download Via Blue-Panal.
    Top Poster icaicm's Avatar
    May 2008
    In Here
    what image is on the box. usually its in pluggings which you access via pressing the blue button. if its not there then you will have to add it.
    Administrator
    Devilfish's Avatar
    Feb 2008
    Apr 2008
    If your using a DW image it's already installed and accessed via the Yellow button
    Cheers
    May 2008
    Quote Originally Posted by nilrem View Post
    Cheers
    had the same prob as my image was an old one....had to update my image in order to get the tux commander.
    Jul 2008
    I'm using Commando 4 cos I've found it to be more stable than some of the later images but I want to install tuxbox commander. Where can I download it and where do I install it?
    Cheers
    Default dreambox 500
    i mounted the folder to my db but i dont know how to find the plugin from thet folder in db and to instalit, please help
    alot of tnx
    I just can not connect the db500 on net to download the Tuxbox. Any help?
    I need some help also.
    I'm trying to manually install the software by mounting a drive on my laptop, but the DB is not showing the files within my share.
    Plzz help ...
    Ok, share is working thanx to all within this forum ...
    When I install TuxBox, i receive the message that the installation was successful ... but the plug-in is not showing in the plugin folder ...
    plzz help, i am a newbie with this stuff ....
  13. #13
    Aug 2010
    Default hi
    thnks for sharing .,.
  14. #14
    Oct 2010
    how do i install a plugin? my dreambox 500's ftp password is not dreambox
  15. #15
    Feb 2009
    have you tried commando
