Results 1 to 15 of 17
    Member peugeot's Avatar
    May 2009
    Default Peugeot 206 magnetti marelli IAW 1AP.80
    Hi guys ,
    Anyone know what common areas in this ecu fail ?
    Canott communicate with ecu .Engine runs fine with swapped immo off ecu from another car . No earth out to double relay supplied by ecu ,so no power to coil and fuel pump etc. Shame to bin it if it was a relatively easy repair and problem is customer is withoiut much money :[
    Many thanks
    electrones's Avatar
    Feb 2012
    Around C.V
    Hi friend
    Verify "corrosion" power strip wiring, fuse box located between the engine compartment and relay module management system of the engine. good luck, -_-
    HI, didn't he say that the engine run fine with another ecu. the problem should be in the ecu itself.
    my little info, must be a small plcc of udk2559 which control double relay.
  4. The Following User Says Thank You to Zmann For This Useful Post:
    peugeot (10th July, 2016)
    May 2009
    Quote Originally Posted by Zmann View Post
    Yes engine runs perfectly with swapped ecu , Many thanks Zmann I shall have a small investigation and possibly try to source one from my large collection of broken ecus over the years . It is such a pity for customer to have to pay maybe 700 ish euro for replacement ecu when theirs could be repaired quite cheaply and if it didn't work ,well at least we tried and maybe learnt something along the way.
    I have done some pcb soldering in the past and have some tools for programming namely mpps v12 and kwp2000 Bdm 100 on order . I'm fairly sure that these will be not much good with this ecu and will probably require some form of desolder and programmer if I wanted to try to immo off on second hand unit ?? Anyone recommendations would be welcome .
    Anyway thanks guys for a great forum and sharing your valuable information.
    May 2009
    Quote Originally Posted by peugeot View Post
    Anyone else have any input or comment ?
    I don't think any of your programmer can do this ecu.
    two solutions to immo off this monster
    - clock file, find it and the instruction here on dk, never try
    - proper programmer to deal with TMS374, the affordable one is xprog-m (clone)
  8. The Following User Says Thank You to Zmann For This Useful Post:
  9. #7
    Spain
    Hi M8,
    It?s not possible comunicate because comunication goes through abs unit.
    Chech fuses an try comunication to abs unit.
    Regards.
  10. The Following User Says Thank You to jnoroeste For This Useful Post:
  11. #8
    May 2009
    Quote Originally Posted by jnoroeste View Post
    Hi M8,
    Regards.
    Thanks Jnoroeste , Year 2000 car with no abs .Its definetely fault in ecu .I also swapped this ecu into another car and no comms there either . Looks possible to be a plcc problem as poster above says .Thanks for your input also .
  12. #9
    italy
    If I remember correctly if the immobilizer system is not working properly the control unit not communicates with the diagnosis and no control the pump relay and so on.
    Have you tried doing immo off on original ECU?
  13. The Following User Says Thank You to autorisp For This Useful Post:
  14. #10
    May 2009
    Quote Originally Posted by autorisp View Post
    No problem in bsi transmitting unlock code incl. keys are learnt and transponder marker code recoginsed.
    Van wiring checked between bsi and ecu all good .
    Defo internal ecu fault .(new double relay also fitted)
    Thanks for the reply anyway . Was mostly wondering what , inside this ecu, causes this anomaly.
  15. #11
    What the tool do you have, Lexia/PPS?
    Possibily your ECU is internally serious damage.
    But better checking the K-line and L-line from diagnosis plug back to the ECU first. What's the plug...
    OBD 16 pin plug: OBD Pin7 to ECU pin31 K-line, OBD Pin15 to ECU pin12 L-line
    If it's the two pin plug, two of them are K and L (and if Lexia you need the specially provided cable with battery clips)
  16. The Following User Says Thank You to Zmann For This Useful Post:
  17. #12
    May 2009
    We have genuine diagbox , its 16 way connector . Am able to comm with swapped ecu , read faults etc so no problem in K line. Time for customer to bite the bullett and buy new ecu .
    Thanks for all your replies !
  18. #13
    Oct 2008
    Hi, the problem must be in tms 374, try to reprogram it or replace it .
    regards
  19. The Following User Says Thank You to AMON For This Useful Post:
  20. #14
    May 2009
    Quote Originally Posted by AMON View Post
    regards
    Thanks Amon , dont think my bdm will allow reprogram of this ?
    Probably desolder and read will be the job .
    Do you agree ?
    thanks for reply
  21. #15
    Oct 2008
    you can use x prog-m, just need to lift some pins
  22. The Following User Says Thank You to AMON For This Useful Post:
