Results 1 to 3 of 3
    Default Vauxhall/opel EPC
    Hi Does this still work Vauxhall/opel EPC 4.0-3.2010 tried on my new laptop running windows 7 following these instructions This is the order with the steps for SUSSESFULL installation:
    1. We mount the image (Prefering program Alcohol20%)
    2. From the Folder "GMGInfrastructure" we run the GMGInfrastructure.msi and we choose "Standalone"
    3. From the Folder "GMEApplication" we run the GMEApplication.msi
    4. From the Folder "GMGLocalDB" we run the GMGLocalDB.msi
    5. From the Folder "GMERomDB" we run the GMERomDB.msi and we copying the Data Base to our HDD
    6. IF we using HDD with letter "C" for the Default installation Folder, WE MUST run NOW
    the batch file "GM EPC 4.0 HotFix.bat"
    7. We waiting to finish the "Fixing" and we rebooting the Computer!!!!!
    8. Now we run the program from the "GM EPC 4.0" url
    Finally we can copy THIS url to the desktop OR the NEW FINAL url that provided from the GM EPC 4.0.....
    Tip-Hint:
    When we MAKING "Updating" we are following THE SAME PROSEDURE!!!!!
    no joy
    Any Help anybody please
    clacker
    6. Open the Start menu, execute cmd.exe, and the pop-native DOS window execute alternately three commands:
    SET PATH = "C: \ Program Files \ Snap-on Business Solutions \ Global EPC \ GM \ jre1.6.0_02 \ bin";% PATH%
    cd "C: \ Program Files \ Snap-on Business Solutions \ Global EPC \ GM \ Configurator"
    java-jar Configurator.jar
    Before their execution must go to the root of drive C: by typing "cd \" without quotes of course, but with a space between cd and \
    string takes the form C: \>
    And then execute commands very carefully depending on what type or just copy from here. Hot keys in DOS Osovski window does not work, only the mouse.
    You can use the attached file CMD. You must first correct the path to the folders according to your preferences.
    7. Reboot your computer
    8. Open IE and enter the address of the code:
    http://127.0.0.1:351/PQMace/launcher.html or http://127.0.0.1:351/PQMace (all different)
    cut and paste the SET PATH into DOS and it will then work
