Page 2 of 2 FirstFirst 12
Results 16 to 30 of 30
  1. #16
    ray-ray's Avatar
    there is only 3 real version everthing else is fake. the first version 5.11 then 5.30 and last was in spanish. i believe that the last version came out in 2005 or 06 .once a clone hit the market there a short window before the oem protect there system. that why the tcode pro was design to protect there software.
  2. #17
    bangreno's Avatar
    Oct 2011
    Unhappy
    Quote Originally Posted by pkeeney View Post
    you have to use the type 2 adapter with the Pacifica ,caravan and liberty,,, select Pacifica under Chrysler.
    Tried all combinaison with and without ADC139 under Chrysler , not working.
    Really confused.
  3. #18
    DK Veteran Automat's Avatar
    Chuichu village, AZ
    A failed connection could be from bad fuses, check all related fuses.
  4. #19
    bangreno's Avatar
    Oct 2011
    Quote Originally Posted by Automat View Post
    Car is working with original key , so I guess immo system is powered.
    I successfully connected with Autocom CDP , mean OBD socket line seem to be OK.
    I tested with a scope and found that T300 use K-Line for Pacifica and signal is ok without adapter.
    Will now check if output is ok with adapter 139
  5. #20
    bangreno's Avatar
    Oct 2011
    Can somebody check if Adapter ADC139 wiring is good
  6. The Following User Says Thank You to bangreno For This Useful Post:
    n599fbm (20th July, 2014)
  7. #21
    Aug 2012
    Ray-Ray mid 7's came out under spanish has fobik A, up to can pin read and all can pin read. They called it ver 8.50 spanish. Also came with some nissan ibfibity that is still being used by factory 13. rest was just plain tcode, like some one bought cheapest tcode and added 5 software versions of chrysler for it. Gameboys used H8 micros Have not seen anything added to the pro that the old hardware could not do. Except the t300 could not store the whole volvo dump unpack get pin code then programm. I would take a old one and add newer protocalls. but a j2534 would be better. They need to add alot of more diagnostic options to the cardaq for the price it can flash but what good is it if we still have to have oem to sync every thing.
  8. #22
    T300 can do the job if you use the right AD138.most of the clone are useless
  9. #23
    Nov 2012
    The remote not working means he used the wrong key. It can be unlocked and the right one used just exchange shells.
  10. #24
    bangreno's Avatar
    Oct 2011
    According to T300 manual , must select Chrysler / Pacifica , no adapter.
    But still connection failed.
    Tested T300 on Nissan Murano , Peugeot 406 2002, no problem.
    My Jeep use ID46 (7941)
  11. #25
    Sep 2012
    i am not sure about u all guys experience...but i never had any success on Jeep (esp Cherokee) on SKIM models even with both Adapters...on T300+ and SBB
    Someone mentioned here, with right adaptor, it is possible to do..i got both adapters while i bought t300, Should i buy new ones since the provided adaptors are bad n wont work??
    in that case can someone recommend me a reliable source to buy from??
    And also what about cherokee 2004+, can T300 do those car untill FOBIK models??
  12. #26
    prusony's Avatar
    Belarus
    Scheme working adapters ADC-138 & ADC-139.
    Tested on real cars ....
    New Year's gift.
    With best regards , Alex.
  13. The Following 2 Users Say Thank You to prusony For This Useful Post:
    n599fbm (20th July, 2014), yellowstilo (25th May, 2013)
  14. #27
    Nothern California
    i only have success with can system of chrysler since type 1 and 2 are many time optional most time plain metal key do the job
    Now in the clone section sbb mvp what the coverage on fobik system never try
    Knowledge is the Key
  15. #28
    Sep 2012
    Thanks a lot Alex for the diagram... unfortunately, i have no much idea abt electronics assembling... is there anyone who knows any seller who sells this adaptor.. my friend bought from aliexpress and works but he lost the seller contact..
  16. #29
    camelgd's Avatar
    Jan 2011
    South Illinois
    Check my post this thread 31 October. I have used this a dozen times on type two-no failures. Many places sell this same one, red one works..
  17. #30
    Sep 2012
    Quote Originally Posted by camelgd View Post
    thank you....sorry my mistake...didnt see ur link...thank u
