Results 1 to 15 of 22
    Drobeta Turnu Severin,Romania
    Talking Opel Astra G 1.7 DT stopped while driving and does not start anymore
    Hello everyone,I have a problem with a Astra G 1.7 dt.It stopped while driving and it does not start anymore.On my mega macs 55 I can't get any fault codes.I removed the Fuel Injection Pump module multi-plug and still don't get any fault codes.Is it possible that the Fuel Injection Pump Module to be the cause.I know that I have to get some errors when the module is broken.Thank you and sorry for my bad english
    jarecki55's Avatar
    Poland / UK Leeds
    Check RPM when crank, maybe rpm sensor go dead?OR shut off valve on injection pump
    busaman's Avatar
    suffolk uk
    what fault codes does it have ??? if it has a spill valve related code and there is a small (pump ecu) down the back of the engine held on with 4 10mm bolts take it off open it and look for a dtr solder joint on the board you will see it just resolder and that should be it,
    7.31sec@203.3mph
    I checked the live data I've got nothing on the rpm.Then I cheched for error i've got the error :"P0251 Injection pump fuel metering control A cam/rotor/injector circuit mallfunction". I deleted the error and cheched live parameters and now it's reading the rpd untill it get the p0251 error(10-20 seconds).
    busaman's Avatar
    suffolk uk
    open up the fuel pump ecu,
    7.31sec@203.3mph
    busaman's Avatar
    suffolk uk
    i presume this is the japanese engine??? with the injectors at the back of the engine as you have not given much detail.
    7.31sec@203.3mph
    yes...it's the isuzu engine
    Senior Member kardi78's Avatar
    Sep 2012
    Hungary
    Quote Originally Posted by herman View Post
    Disease Type: feeder control electronics, you can find at the engine behind.
    PICTURES:
    Allready have it on my desk,now i'll open it to see what happened.
    Normally you need to confirm solder points,if all ok need to remove board to see components that could be damage like diods
    i've confirmed the solder points because it were loose but i get the same error and the car does not start.Now with the solder points done it reads the crankshaft rpm and the pump rpm
    Any fault with diagnostic ?
  13. #13
    Now i get the code : "P0370 Injection pump position sensor - malfunction.
  14. #14
    But it reads the rpm on the pump in live data.
  15. #15
    remove board from ecu and see if you have any damage diod,ic,...
