Results 1 to 2 of 2
    Default Help Wii backup disk channel
    Hi I've just soft modded my wii using modmii and its worked no probs for my usb hdd but I also need a backup disk channel (to play my backed up disks) and a forwarder can someone point me in the right direction? Thanx
    DK Veteran Keithuk's Avatar
    Aug 2010
    England
    Well to play burnt discs this will depend when your Wii was made. 2009 and after you can't play burnt discs you could check the Drive date with sysCheck. Even though my Drive date: 2008.12.18 I still can't play burnt discs not that I want to as that even more waste of money.
    If you do want to try and play burnt discs then you would need NeoGamma. I assume there is a forwarder channel in there. You need to burn these games with ImgBurn which is free. You will need quality DVD's not these 100 for ?10 then you need to find somewhere to store all these discs, its not really worth if your HDD is working properly.
    You could do with posting your sysCheck report as instructed in that link as I think NeoGamme R9 will need the later d2x installed.
    Keith
    2010 Golf GTD (170)
