Results 1 to 9 of 9
    Lithuania
    Default Passat 1,9 tdi 2003 year ABS/ESP problem
    Hi, have problem after removing angle sensor G85, and driving car 2 days. Now I have 2 active errors and one error wrong codding......:
    Address 03: ABS Brakes Labels: 4B0-614-517.LBL
    Control Module Part Number: 4B0 614 517 G
    Component and/or Version: ABS/ESP front 1728
    Software Coding: 00000
    Work Shop Code: WSC 00000
    VCID: 254AF3CAD3BB1034
    2 Faults Found
    01424 - Yaw Rate Sensor (G202); Reference Wire
    57-00 - Electric Circuit Failure
    01423 - Lateral Acceleration Sensor (G200)
    Before has only one error steering angle sensor . Now error gone, but have these 3 errors.
    tiguan's Avatar
    Ashraf6119's Avatar
    UK
    Did you try to carry out the Basic Settings for all those fault codes..............
    Make sure you enter the security code every time for each basic settings
    The code is 40168...........
    Thanks Ash
    Oh yes if my post was helpful than Please don't forget to press the Magic word Thanks
    Lithuania
    Thanks for info, I made codding, basic settings, adaptations..... But still have 2 errors;
    Address 03: ABS Brakes Labels: 4B0-614-517.lbl
    Part No: 4B0 614 517 G
    Component: ABS/ESP front 1728
    Coding: 04255
    Shop #: WSC 12345
    2 Faults Found
    check wiring supply voltage or g200 fault
    Lithuania
    But before I has only steering g85 error, and after disconnecting and driving car I got these errors
    Strange. ....
    Where located g200 sensor ?
    parla
    muy bueno una vez me paso para adaptar un anillo de airbag de segundamano, pero no sabia el login.
    my girlfriend gives virage sensor failure (202) changed the ABS module and still gives the same error, also changed the wheel sensors, and sensor probe 202 also with several
    Ashraf6119's Avatar
    UK
    The Yaw Sensor and Lateral Acceleration Sensor will be located under the Steering Column......
    It will be looking something like this in the picture........
    Thanks Ash
    Jan 2013
    the g200 sensor can be repaired
