Results 1 to 15 of 22
    Aug 2008
    Default i need ford focus 1.6tdci dpf off
    8M51-12A650-XE 0281015242 THANKSS...
    assitutto's Avatar
    May 2009
    Milano, Italy
    your file off
    Aug 2008
    thanks my friend but don't work
    Off by switch on this.
    Pro VAG Petrol Tuning | Pro DPF Removal | MED17 TPRot Removal
    Aug 2011
    uk
    Default re dpf
    If you flash with mpps via obd be careful as can corrupt eprom, i did one last week and then needed to ids cal file
    assitutto's Avatar
    May 2009
    Milano, Italy
    Quote Originally Posted by J_amb_o View Post
    i made dpf off by switch
    and this solution in 100% tested
    Quote Originally Posted by flyins View Post
    i have to do one today,as i want to write with mmps,will know what exactly is happen?you lost the injectors coding or something?
    regards
    Aug 2011
    uk
    Hi friend no didnt lose injector coding,(even though that can happen), it lost variant coding fault code "P1187 variant coding", i had wrote different remap to this car successfully three times with mpps, but a week later i wrote a file back to car and then i had engine malfunction, car still started but about every three to four starts of the car i got engine malfunction on lcd on dash with a bleep and bad acceleration. No mil light lit up though. When scanned got p1187, so then it needed to have calibration using ids. You must use genuine ids or GOOD clone to do this and the right calibration file for the ecu. Search on here for P1187 and you will see this has happened quite often. And yes i had good voltage to car battery using external voltage to battery.
    Re wrote using FG galletto with dpf off file after calibration which wrote good
    skywoker's Avatar
    May 2012
    ROMANIA
    Default Ford Focus 1.6 TDCI DPF Off
    Here your file, pass in PM. Careful writing process use gal2.
    Oct 2010
    Try to look first at the date of previous post before posting yourself.
    Dec 2010
    FAP need off
    Volta and ecusafe are not good.
    Greetings DK
    Quote Originally Posted by jaelgti View Post
    FAP need off
    Greetings DK
    1E806D change from 01 to 00 (8bit)
  13. The Following User Says Thank You to blazej1200 For This Useful Post:
    jaelgti (21st May, 2014)
  14. #13
    Rito's Avatar
    Quote Originally Posted by assitutto View Post
    Switch is a software??
    What you use for do fap?
  15. #14
    xanubysx's Avatar
    Sep 2010
    EUROPE
    One bit solution work ..on this ecu...
    Do not forget to THANKS !
    SWIFTECH FULL
    ECM Titanium FULL
    KESS V3
    AUTOTUNERS
  16. #15
    Dec 2010
    Quote Originally Posted by xanubysx View Post
    What do you mean?
    I do not understand
    regards
